Well I had so much fun with my smaller UL-1 this past summer that I just had to look into a bigger boat that I could build into a fast electric for racing this next summer. Talked with Mike from ML Boatworks quite a bit and decided to go with the 1/8 scale 171 Extreme kit the Miss Elam boat.
Now I have been an airplane builder for quite some time....since I was 15 when my dad and I would spend hours in the basement working on models. No servos then...just escapements....LOL. But this is my first try at building boats, especially an Unlimited Hydroplane. I will also be posting this build in another forum and I'll try my best to keep up with both of them.
In any case I will be looking for a lot of ideas and information from anyone that would like to chime in. OH....and I take the negative criticism too....as long as your nice about it....LOL I don't think of there ever being a dumb question, except for those we don't ask. So if some question sounds a little on the dumb side, bear with me. Remember I’m new to boats and want to learn more.
What I'm planning for power with this boat after talking with Mike at ML Boats is the NUE 1527 1Y on 8S. 10S if they will fit. But I'm thinking for a racing profile that 8S is going to be more than enough. Not sure on the ESC as yet, but thinking it’s going to have to be at least a 240amp. Was going to get more ideas from you folks on that. Also the running hardware from Accu-Tech seems to be the way most folks are going. Again any other ideas or suggestions out there are welcome. Ordered the cowl from RC Boats and the Wing set from Phil Thomas last week....so expecting them soon.
I have been reading up on the rules for these boats, but as we all know sometimes there are ones we might have missed. So if you know of ones that seem to keep coming back and biting guys please let me know. I think the biggest one that I have seen is that the drive dog cannot extend past the transom, so that means a thru hull drive shaft support. Appreciate your ideas of the size drive cable and stuffing tube to be used. Was thinking of the 1/4" reduced to 3/16.
Well I got started on this over this past weekend and pretty much have the center section done. Nice thing about this kit is that it builds pretty much in 3 separate sections. If you have a flat surface to work from, that’s about all you'll need to build a nice straight and square boat frame with this kit. Everything is perfectly laser cut, best I've ever seen. And everything fits perfect. The next thing to move onto will be the sponsons which should go fairly quick. When I ordered the kit I also ordered all the 1/4X1/4 and 3/16X3/16 square stock, plus all the sheeting for the boat from Mike.
I've attached some build photos from this past weekend. Pretty much started off by tacking everything together with thin CA and Med CA. The hull bottom sheet is all one piece. I thinned some 30 min epoxy and applied it to all the bulkheads and hull stringers and then positioned the hull bottom sheeting. Weight down and wait. At the same time I went over all the other joints with the thinned epoxy mix for a better bond with formers and stringers. I'll be coating them again later when I get ready to coat the inside of the boat.
Any suggestions are appreciated on what your using for sealing your boats....West System...etc.
Thanks All! Can't wait to get it on the water this spring. It’s all Ice right now...LOL
Mike S.
