I havent built a mono just yet but I had some ideas on how I would do the drive tube and have it adjustable. I've seen people do a flooded tube with a boot on the interior end, good idea but I wanted to be different. So I used an idea from my cat builds. I like the idea of being able to remove the drive tube if I need to so I make a slip joint. I did the same on this little mono. This thing came with a strut.....but it was just for looks. I could not believe it when I figured out it was non adjustable from the factory...who does that? Lmao! Anyway I made a short one as it does need much adjustment. Here's what I did:
Ripped out the stock drive tube. Drilled a hole bigger for my brass flooded tube. Removed the epoxy from old tube.
Then I cut my brass tube. 27/64 is what I used. Then I found a nut to fit snug in the tube. Drilled it to fit the slip tube.
Assembled it.
