Results 1 to 22 of 22
Thread: quick and easy flooded stuffing tube
    Oct 2013
    la
    8,740
    Default quick and easy flooded stuffing tube
    I havent built a mono just yet but I had some ideas on how I would do the drive tube and have it adjustable. I've seen people do a flooded tube with a boot on the interior end, good idea but I wanted to be different. So I used an idea from my cat builds. I like the idea of being able to remove the drive tube if I need to so I make a slip joint. I did the same on this little mono. This thing came with a strut.....but it was just for looks. I could not believe it when I figured out it was non adjustable from the factory...who does that? Lmao! Anyway I made a short one as it does need much adjustment. Here's what I did:
    Ripped out the stock drive tube. Drilled a hole bigger for my brass flooded tube. Removed the epoxy from old tube.
    Then I cut my brass tube. 27/64 is what I used. Then I found a nut to fit snug in the tube. Drilled it to fit the slip tube.
    Assembled it.
    Oct 2013
    la
    8,740
    Then I filled with jb weld to hold it together. Recess the nut some, slide tube in a little and put jb weld around it.
    Slide it in and check fitment.
    Oct 2013
    la
    8,740
    I'm sure you can see why I needed to so this and upgrade to 3/16 flex at the same time. That motor you see is a good bit more power than stock.
    And finished. I point the front of the boat and poured epoxy in to hold the flooded tube in place. Thought this may be helpful in giving some ideas. In a custom built boat I would make the flooded tube a little longer but this serves it's purpose. The stuffing tube slides through it btw, put a little silicon to seal it.
    Mar 2011
    CA
    1,431
    Nice little how to. Glad you did this, read you describing it on the thread where the boot was used. I was just gonna fill the end with resin/filler and drill out a hole then put the slip tube. I like the nut to keep it centered.
    Oct 2013
    la
    8,740
    Quote Originally Posted by TheShaughnessy View Post
    Thanks! I actually angled the tupe up slightly to help with the angle of the flex tube. I mainly did this because ive had people pm me on how to do it. Why, I have no idea because ive never done one until now. I've told them how i would do it, but now i had a reason to need to in this boat. it had a really bad negative angle on the prop that i wanted to level out. Well when i tried to angle it, the drive tube broke. so hence the reason for this thread. i'm sure theres a better way, just wanted to throw some ideas out there. I'm fine with anyone posting in here how they did thiers.
    Mar 2011
    CA
    1,431
    Are you really gonna run that motor In there?
    Mar 2014
    Ma
    1,951
    Looks good. But with a flood chamber that short, how much adjustment do you actually get?
    I'm not sure how long it actually is, or if the nut acts as a pivot point in some way?
    I totally understand this is just a test of the idea, and given the opportunity you would make it longer....
    Oct 2013
    la
    8,740
    yes, why?
    Oct 2013
    la
    8,740
    Quote Originally Posted by Luck as a Constant View Post
    I dont need much adjustment at all. i'm just playing around with this boat. the tube actually slide so i can add negative or postive prop angle and about 3/16" up and down stru adjustment. better than nothing for sure. If this thing does as well as i hope, i may rip the interior out and redo it travis style. lol
    Mar 2014
    Ma
    1,951
    Haha no doubt man.
    Mar 2014
    Ma
    1,951
    I have a habit of completely rebuilding factory crap. This was a factory white ibanez. Can't have that tho lol
    Jan 2009
    Va
    896
    I too, liked the idea of being able to remove the drive tube if I need to, maybe going from no liner, to lined. On a mono however, I still wanted to use a stinger. Using button head screws, and J B wield I
    secured a piece of sheet metal to the stinger. Even though the motor is mounted far forward, I still needed to angle the tube up. I did this by shaping a small block of wood, and glued it to the hull. The
    tube was secured to the block with a plastic pipe hanger, 2 small screws, and A LOT of glue, not pretty, but it ain't going anywhere, a radio box goes over it. Used the largest rubber boot Steven sells, and a couple of clamps.
    The T bar oiler adjusts up down, left, and right, and locks the stuffing tube in place.
    Mar 2011
    CA
    1,431
    I thought about keeping the stinger on my mono build but I was like, not enough meat on this stinger, now I see how you did it.
    Oct 2013
    la
    8,740
    What's wrong with My motor choice? Lol
    Jan 2009
    Va
    896
    Quote Originally Posted by kfxguy View Post
    In my high school auto shop class, we put a 427 in the back seat of a Corvair, so I would say, not a darn thing.
  16. #16
    Oct 2013
    la
    8,740
    Well this boat can only hold a 3s pack without getting badly unbalanced. So I plan on running on 3s only. I have this same setup in my son's 26" hydro. It's not unruly. 40mm 1.4 pitch prop and it does 30 mph.
  17. #17
    Mar 2011
    CA
    1,431
    It just looked big in there , I was thinking higher cell count. Maybe whip up a cf rear support?
  18. #18
    Oct 2013
    la
    8,740
    I had planned on it. I have to wait till the water jacket makes it here.
  19. #19
    Apr 2011
    CA
    5,666
    Quote Originally Posted by runzwithsizorz View Post
    it's the only way.
  20. #20
    Apr 2011
    CA
    5,666
    Travis, that is a great set up, can be applied to many other RTR boats, thanks for sharing!
  21. #21
    Oct 2013
    la
    8,740
    Quote Originally Posted by tlandauer View Post
    Thanks! I'll be building my first mono fairly soon and will apply something like this to it except using carbon tubes.
  22. #22
    Aug 2013
    Fl
    2,451
    That's what I'm talkin' about, it's easier to slow it down than make it go faster!!
