Hey guys, I have a CF cheetah running leopard 4092 1480kv I'm runing 4gens ace 5000mah 3s hard case packs, I have them wired to make a 10,000 may 22.2 battery. Runs great solid 5-6 minutes hard running. Its spinning an x447/3 and overall its running fine and cool. Want to get some more speed out of it. Any prop suggestions that would benefit speed? Smaller more rpm? Bigger pitch? It has ridiculously insane traction and even at ten MPH will flip into the air if I hit the trigger. From dead stop punching it will send it skyward and back flipping. So smaller and some slippage should not be a bad thing it has to much traction i think. Today will probably end the season for me as the lake today in New York had some ice on the downwind side so its over. But looking to get some stuff together for the spring. I had my step daughter shoot some vid today and the temps were cold so I think that effected top speed as batteries were cold. It usually seems a touch faster. I bent the rudder control rod last month and since I straightened it it seems week. As you will see the rudder just snap rolls the boat when I started putting in steering input at full throttle. Got change that to a better rod. One time it got air born because I thought I had enough speed to punch it out. But any suggestions would be appreciated. Thanks.
