Page 1 of 2 12 LastLast
Results 1 to 30 of 35
Thread: Spektrum DX3R
    May 2007
    1,603
    Default Spektrum DX3R
    Just curious if anyone has tried one in a boat yet? I have been using my Futaba 3PK with Spektrum module and the older SR3000 receivers in all my boats and cars for a long time and never once had a problem or so much as a glitch. I wanted to try some of Spektum's newer smaller receivers but with the module in my 3PK I can only use the SR3000 receiver so I decided to give the DX3R a try. The radio has the capability to use any of the Spektrum receivers so I went for it. I am just curious if anyone here has tried one so far and what they thought about the radio....and even more important if they noticed any problems.
    Team Liquid Dash
    wa
    1,384
    Etown on here uses one in his boats and he has had great results. I wish I had the cash. Rx units are much more expensive than I realized and as long as you keep them dry they work flawlessly as far as I can tell. As far as I know he has had no problems with it and has actually let some of us use it in our boats when our Futaba FM systems are acting up.
    Dec 2007
    WA
    102
    One of the big plusses the DX3R has is the steering knob can be switched over to either side of the pistol grip. Our club's left-handed drivers have found this a godsend. I have heard that the programming features are also more straightforward and easier than previous Spektrums.
    ma
    8,693
    I have and love it. It also works with the older rx's. The main diff I see is water proofing. The new rx has no button to bind it. So its easier to coat with the dp270.
    Steven Vaccaro
    Jun 2007
    5,190
    Steven, there have been discussions on the pro's and con's of 2.4ghz and competitor claims. You and many other people I trust are using this technology. I still love my Hitec CRX but after viewing the disaster that struck C SMOCK. I am wondering, I use a receiver to see if anyone is transmiiting on any of my frequencies, but what happened to Casey , frightens the hell out of me, as I do not wish to see a boat I spent a lot of time in building beinig destroyed by a twit
    Douggie
    May 2007
    1,603
    Steven I am glad to hear you guys are having good luck with the Radio. I am kinda a if it isn't broke don't fix it guy. My 3PK and Spektrum module have worked perfectly over the last few years but I wanted to try a new radio and if this works like it should I will be happy.
    Team Liquid Dash
    7,279
    Quote Originally Posted by Flying Scotsman View Post
    Douggie
    Thats why I love my Spektrum, 2 years on all sorts of setups and no glitches and no worries about "twits"
    May 2008
    218
    i got one.. i dont run it in my boat yet but i have been running it in my rc offroad trucks and it is by far the best radio i have ever had.. it is also super light(doesnt weigh anything).. its a great radio..
    on
    1,921
    i will give you some feed back shortly on it Ray.
    EYEKANDYGRAPHICS
    www.rclipos.com
    wa
    1,384
    As Taylor stated once before and I see it now... plan on an easy switch-boat transition or plan an extra hudred bucks to each build. I personally dont like switching once I have stuff nailed down.
    Mar 2008
    Au
    806
    I have the 3xr and love it. BUT i did have all sorts of trouble using the sr3000 receivers with it. I have since switched to the newer sr3100 receivers and not had a single problem with it..
    Heath
    May 2007
    1,603
    Heath, is it going into failsafe with the SR3000 receiver's? The SR3000 receivers are all I use with my 3PK.
    Team Liquid Dash
    Jun 2008
    896
    I'm running a DX3.0 with the SR3000 receiver and 0 issues. Had it out about a dozen times now and all is working perfect. Never an issue, super responsive. No problems with rolling boat and getting some water on the receiver either (not waterproofed at all). I'm VERY happy with the system.
    May 2007
    1,603
    The 3.0 and the DX3r are two different radio's.
    Team Liquid Dash
    Jun 2008
    896
    Quote Originally Posted by Raydee View Post
    yes I know. I was just commenting that the dx3.0 is flawless as well, and considering it comes with 2 receivers, it's an easy choice.
    Mar 2008
    Au
    806
    Ray it was getting about 50ft away on the water then shutting down But when i did a land check i could get 3 times that away from it and it worked fine.. Spektrums answer was not to use it on water as the glare can interfere with the reception. Once i swapped out to the newer receivers i had no issues..
    Heath
    Jun 2007
    5,190
    I just posted an invitation on RRR to users of the different technologies to advise of their findings. I have never seen in any marketing blurb any advantage that 2.4ghz has over FM, appart from no frequency clash issues, which is their claim to fame, but what about other issues, which have been docummented. Hitec, still does not offer this technology?
    PS any flyboys out there to offer an oppinion, as they are the technology leaders.
    Douggie
    May 2007
    1,603
    I have been using the Spektrum DX7 in my $2500 heli for a couple seasons now and have had no problems at all.
    Team Liquid Dash
    Jun 2007
    5,190
    Ray, it is the water reflection issue that interests me and great to know of no issues with aircraft.
    Douggie
    May 2007
    1,603
    I ran 4 packs with my DX3R today in my Whiplash and my older SR3000 receiver with the antenna INSIDE the hull and not a glitch. I ran the boat way to the far side of the pond and all the way across the pond and so far so good. I also tried it right at the waters edge and up on shore some with no difference.I never thought I would say it but the radio is so light I really noticed the difference. I still hate the timer but I will get over it.
    Team Liquid Dash
    Aug 2008
    76
    How much antenna needs to be up in the tube? I have the Futaba 3PM-2.4G and the antennas are very short with this new stuff. If I put the receiver in the waterproof box of my SV, only 2" shows in the tube. Do I need to move the receiver to raise more antenna or will I be ok as is. Need advice before trying it.
    Sep 2008
    1,435
    One of the guys I flew with this weekend had his $20K jet (an Ultra Bandit) flying on Spektrum. The frequency board had ONE guy with a 72MHz radio. And there were probably 50 pilots there, well over 75% flew Spektrum. I sold one of my 72MHz modules (Hitec Spectra) last week and have the other for sale (with rx's), as well as several 3PDFs for surface stuff.
    I ain't looking back!
    Andy
    May 2007
    1,603
    Andy I was so scared that your post was going to be bad I was almost afraid to read it
    I remember back about 7 years ago when a company called Model Avionics was going to release the first ever 2.4ghz radio for air use. We waited and waited but it never happened. I remember thinking that it would be the single best thing to happen for RC flight in a lot of years. I am glad I switched also and until there is something that is way better on the market I am sold!
    Team Liquid Dash
    Sep 2008
    1,435
    Quote Originally Posted by Kfoss1 View Post
    Only the last 1.5" needs to be visible. That's all that's really "antenna" - the rest of shielded.
    It always helps to have it as high as possible.
    Andy
    Wa
    5,905
    Is it true for the last 1.5in on the older spektrum recievers also?
    Quote Originally Posted by AndyKunz View Post
    Andy
    Billy Graham
    Sep 2008
    1,435
    I'm pretty sure it is. The extra length is there to get the antenna up high.
    Andy
    Aug 2008
    76
    Thanks for the replys guys, I`ll give it a try. To have any more than 2" up the tube, I would have to relocate the receiver out side the water box making it vunerable incase the hull takes on any water.
    Jun 2008
    896
    I keep the antenna in the hull. Boat is completely sealed. Checked with antenna sticking out and in the hull, and didn't really notice any chance in range. Zero glitching with both trials, on the SR3000 receiver.
    Jun 2007
    5,190
    Andy, flying is not what worries me, it is boat useage, water reflection and antenna problems. I love the thought of no frequency clashes, but there has been much debate on range issues, loss of power at the receiver and so on. The Futaba FAAST system seems to have most of these issues resolved, but, I am still leery of changing out my Hitec CRX Spectra, as it works. I have viewed the XPS site and they seem to have interesting 2.4ghz products http://www.xtremepowersystems.net/index.php
    Douggie
    Sep 2008
    1,435
    Before you spend a penny on XPS, check out his reputation on RCGroups. Caveat emptor. We have a guy at the field in PA who can't give away his XPS system (he upgraded to Spektrum, too). I was looking at his stuff very carefully before I settled on Spektrum.
    Andy
