I think you are refering to older ones Bill. Now I have an older one and have experienced zero problems used in both wood and carbon fiber hulls with the antenna extended as far as possible out the hull. There are a bunch of older spektrums that are used in ERCU with no problems. I know for a fact that the new spektrums are also much improved and have eliminated the problems of the early radios. So if you are looking for a 2.4 and decide on a spektrum I would get a new one.
Jim
Originally Posted by
Bill-SOCAL
He is talking about the "Spektrum" brand of radio, NOT all spread spectrum radios. This is a constant point of confusion. The Spektrum brand radios are not proving to be as reliable as some others. Certainly there are people who have had good luck, but it is just that, luck.
A second issue for ALL spread spectrum radios in Europe is that they are limited to a lower power and this negatively effects their performance.
Just to be clear:
"Spektrum" is a brand of radio (JR uses their technology)
Spread Spectrum (SS) is a type of radio transmission
So, all Spektrum radios are spread spectrum type of radios. But not all spread spectrum radios are Spektrum!!
Spektrum uses one type of SS implementation where it locks 2 channels at start up. A SS "channel" is not quite the same as what we are used to, but that is the term they use. If there is interference on the one channel the radio hops to the other channel. It will hop back if the second one has a problem. If both have issues then it locks out. Statistically there is a very low probability of both channels having issues. Their are 40 channel pairs in the 2.4 GHz band where we operate, so they are limited to 40 of their sets on at a time. THe 41st will not turn on since it cannot find a free pair.
The Futaba FASST (Futaba Advanced Spread Spectrum Technology) implements SS differently. It sweeps across the entire 2.4 GHz band allotted for this use 500 times a second. It never pauses it just keeps sweeping. This method makes it nearly impossible for interference to cause an issue. The Futaba FASST radios have been proven to work very well in boats.
Spektrum and Futaba FASST radios do NOT interfere with each other. The FASST radio sweeps the spectrum so fast that the JR/Spektrum radio never knows it is there.
Billy Graham
