I can't believe I've been missing this thread! Great job do far. I like what you came up with on the rear of the motor mounts, pretty slick. Personally I like the hpr hatch better as its sleeker looking...I guess that what I prefer.
I'm not sure why you need a rubber boot on your flooded tube tho. They way I'd do it is I'd cap the end of the cf tube, drill a hole for one size larger brass than your stuffing tube. Pus short piece of it in the end of the flood tube where you drilled the hole. Epoxy it on place. Then you slide your tube. Maybe put a collar with a set screw going though the larger tube to lock the stuffing in place.
