I am also going to try to take advantage of the hooked right sponson which Andy designed into these hulls. The inside running sponsons last step is 1/4" deeper in the water than the outside one.
Neither of the R-42s I've owned had the right sponson deeper in the water than the left - they are both exactly the same depth from the tunnel bottoms. And both sponsons had a slight amount of hook designed into the last step. Has Andy changed the boat's design in the last two years?
