Page 1 of 2 12 LastLast
Results 1 to 30 of 39
Thread: anyone heard of Vac-U-Pickle
    Jan 2014
    ok
    229
    Question anyone heard of Vac-U-Pickle
    ran across these wonder if anyone has any experience with them, good are bad to buy
    thanks
    Oct 2013
    la
    8,740
    Of course we've all heard of it! It's a neat little boat. I'm building one for my son right now...and now I kinda want one for myself!
    Apr 2011
    5,666
    Quote Originally Posted by okieman98 View Post
    thanks
    Ga
    5,267
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Apr 2011
    5,666
    Doug, those hydros look so good in your shop, I am lucky to have bought this one that was built by you! Love it! With the Neu 1509 they were awesome! I may try that for the N-2 Sport Hydro class. (just for fun for myself as i don't race)
    OP: this hydro is not that big but it is a fun and well running boat! I also forgot to say that the hydro you saw in my YouTube clip was built by Doug Smock, I bought it here some years later through a third party...
    Jan 2014
    ok
    229
    looked good running what kind of speed u can get out of them. i think i will order one . might need advice on running gear on this i have never put one together
    thanks
    Jan 2014
    ok
    229
    i was looking at one of the links above wonder what kind of paint he used since they are not fiberglass
    Ga
    5,267
    http://vac-u-boat.com/Painting%20Tips%20Menu.htm
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Ga
    5,267
    thanks
    This link will help you with the build although I no longer use Teflon liners.
    http://vac-u-boat.com/PickleSmockBuildPage.htm
    All of the hardware on this build came from Ray Fuller. The guys can fill you in on other options.
    http://stores.ebay.com/Fullers-Fast-...=p4634.c0.m322
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    Jan 2014
    ok
    229
    thank u so much
    Jan 2014
    ok
    229
    have one more question i have a shockwave 26 bl , dont like the boat to much to slow , i have been told the motor is pretty good in these boats will it fit in the vac-u-pickle and what other parts can i use off of it
    thanks
    Apr 2011
    5,666
    If you have the 1500kv Proboat motor, then it is an excellent motor, speed will be slower than the UL-1's 2030kv motor, the ESC should work as well. I have the latter motor and use a X642 prop as well as a Grim 40x52/3 prop, all work well.
    The motor will fit! The only thing you might have to pay attention is the clearance of the underside of the water jacket. The motor mount that is meant for the Vac-U-Pickle is a low mount, water jacket on the thick side may not clear, you need to slide the jacket slightly toward the back of the end bell. At least that is my finding, could be wrong though.
    Whatever you do, don't part with that motor, that motor can be run with 6s as well. They are discontinued and together with the 1800kv motor , they are well liked by boaters!
    Jan 2014
    ok
    229
    ok thanks i was going to up grade the esc to run on 4 s are 6s what ever i can get in it. speed is the key for me want it to run with my cats. not sure what battery will fit in there
    Jan 2014
    ok
    229
    i just looked it does have the 1500 kv motor, and a 3s 45 amp esc
    also have the the motley crew on 4s to
    Oct 2013
    la
    8,740
    thanks
    The motor is about it. The esc would work but it's a little big in size. ..
    Apr 2011
    5,666
    My Bad, i thought it came with the FasTech 45amp ESC which was rated for 4s. And Travis is right, space is limited.
    I use the AquaCraft ESC, it barely fits across because the current version of the ESC has a longer cap.
    Jan 2014
    ok
    229
    ok then the rx and tx should work then i guessing
    Apr 2011
    5,666
    yes Sir, the MR200 rx is a great unit, while the tx doesn't have model memory, it is still a good radio.
    Oct 2013
    la
    8,740
    I ordered a seaking 60 amp esc which is smaller in size for mine. It was like 44 bux.
    Jan 2014
    ok
    229
    ok thanks everyone, all this info helps alot. cant wait to order it and get started
    Apr 2011
    5,666
    Travis, which version? V2 or V3?
    May 2014
    mi
    643
    Here's mine. it's lots of fun and fast
    Apr 2011
    5,666
    LOl...
    Now this completes the package... Properchopper had long ago posted something like this.
    Oct 2013
    la
    8,740
    The V3. It's very nice looking (like it's big brother) and compact. Came in today....only 2s and 3s tho
    Apr 2011
    5,666
    Good to know!
    Jan 2014
    ok
    229
    y can only ron 3 s on that esc 60 amp?
    Apr 2011
    5,666
    Yes.
    http://www.offshoreelectrics.com/pro...seaking-60a-v3
    Jan 2014
    ok
    229
    ok got lost somewhere with the research i have been doing, lol, i was thinking i saw these run on 4 s. going to order after the 1st of the month so drifting around finding where to get parts and so on.
    Apr 2011
    5,666
    You should get an ESC that is 4s compatible. I think the 90A would be a good choice.
    Sent from my Droid using Tapatalk 2
    Ga
    5,267
    You did. I still run one on 2x2s 5000 45c wired in series with a AQ 2030 and 60a control. It runs great with a M cut X442.
    http://www.offshoreelectrics.com/pro...=dh-aqcom-2030
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
