Results 1 to 3 of 3
Thread: adjustment Help
    Sep 2013
    52
    Default adjustment Help
    I have added a set of trim tabs and also replaced my strut. All seems well except when I go full out the boat goes on edge to the right side.
    Is this what is known s torque roll?? Should I be adjusting the trim tabs or my strut?
    US
    5,557
    Your boat is most likely running wet and the torque roll from the prop tilts it a bit which is then magnified by wet running. Take your tabs up a bit.
    Oct 2013
    VA
    351
    Also adjust the strut up about 2mm. I found that when I put my strut too low the boat would torque roll.
