Results 1 to 19 of 19
Thread: 50 MPH Miss Geico 17?
    Aug 2014
    WI
    30
    Default 50 MPH Miss Geico 17?
    I found a thread regarding a 50mph MG17 project in this forum using a Google search, but I cannot find it by searching this forum from within.
    Long story short version: got my 8 year old son an MG17 for Christmas last year, was disappointed with its performance, made a few mods to it, and got here:
    Motor: 380 Traxxas Velineon 4000kv
    ESC: Hobbywing 60amp
    Batteries: 2 Tenergy 3s 1350mah 20c- to be used first in parallel, then if needed, in series
    Drive: OSE flex
    Propeller: I have a 2inch pitch stainless Proboat, but I would like advice on choosing a better for this application
    Any helpful hints before I try my latest upgrade version of this boat? Has this been accomplished before? Is it physically possible to push this boat to 50 mph?
    Thanks in advance for any help you may offer.
    1,431
    Not really an ideal motor selection. I would opt for something closer to 2800. If you decide to try it as is run a small prop.
    US
    5,557
    Thats really a 2s motor, you are gonna be in the high 40's in rpms with 3s. It should be fast on 2s and a good prop selection.
    For 3s I think this would be best, the 3Y 2960kv model. http://www.offshoreelectrics.com/pro...o-2845&cat=148
    If you have room you could really amp that sucker up with a 2860 Leopard in similar kv or a tad higher.
    Aug 2014
    WI
    30
    Thanks for the responses.
    I picked this motor based on size- it is 1+7/8 inches long and just fits in. When I bought it I did not understand kv's as well as I do now. But I have 2 of the Traxxas Velineons now and no small trucks or cars to run them in, so I am sort of committed to these for now.
    As for a small prop, do you mean small diameter or small pitch, or both? I figure a smaller than 2inch pitch due to the high rpm/low torque ratio of a 4000kv motor. I figure I only need about 10 seconds of run-time at full throttle to accelerate from about 30 to top speed. I am comfortable with frying a motor in a speed attempt, but not the ESC. I am long on motors and short on ESC and funds at the moment (divorce).
    Question: would running this 2 to maybe 3s motor on 6s create more power, even if for just 10 to 20 seconds, or would the extra energy just be converted to waste heat in the motor and ESC?
    US
    5,557
    "Question: would running this 2 to maybe 3s motor on 6s create more power, even if for just 10 to 20 seconds, or would the extra energy just be converted to waste heat in the motor and ESC? "
    You would br turning 80,000 rpms on 6s!!! I would NOT do that. You can easily sell those two motors on a forum, here, RCGroups or RCUniverse in the Traxxas section or General truck section. That would allow you to buy one Leopard 24x45 as suggested earlier.
    The best suggestion I can make is to run it with the 4000kv on 3s if you are set on them and try an x435 or x632. To keep spending to a minimum you can buy a Graupner K 40mm Carbon prop cut down to 35mm for testing purposes, only $5.95 here. Use that as a baseline to buy a permanent beryilium prop.
    Aug 2014
    WI
    30
    Well, I've been pretty busy with work and just finished up the details of this set-up yesterday, 10-13-14. I was worried about all the electronics crammed together under the deck, which I had to do to make room for 2 batteries, but it seemed to work OK on the bench and in the bathtub. Bathtub test confirmed it sits pretty low in the water with the 2 batteries and 60 amp Seaking esc adding significant extra weight over stock. Glued everything together with Locktite Stick and Seal Outdoor. Going to try to do an open water test this weekend. Still don't have an appropriate prop, but I am going to probably order one or two of the props suggested above, or cut one of mine down a bit, and gonna give it a try. I'll shoot some vids.
    US
    5,557
    What motors and voltage did you decide on?
    Aug 2014
    WI
    30
    I am using the Traxxas 380/4000kv motor in the picture with the two 1350mah/3s/20C batteries wired in parallel. I looked up the specs on the suggested motors and they were way too long to fit in the existing motor mount. Going to make do for now with what I have. I ordered the x435 and x632 props from OSE this evening and hope to have them by the weekend. Still working on prop height and angle before I shape a strut out of aluminum or stainless steel. My teak strut now may drag in the water a bit but is easy to replace and/or move. Thinking of angling the shaft up slightly to simulate how I trim my outboard out on my Hydrostream (18 foot ride-in boat) to create bow lift, right now the shaft is about parallel with the bottom of the boat.
    First run = strut flat and 1/8" above the sponson bottoms. CG @ 33% ahead of sponson transoms. Run no longer than one minute (use a stopwatch!) and check temps....and for water in the hull. Good luck.
    Aug 2014
    WI
    30
    Well I plugged in my numbers into the OSE speed calculator and I get a theoretical 49mph with the x435 prop. Maybe 50mph is an attainable goal, but I have my doubts. It just looks like such a small motor to push out that kind of speed. Maybe it will just go up in smoke and flames- but it should be a good show! Will shoot vids of the test runs this weekend if the weather permits.
    9,402
    Your main hurdle will be keeping right side up at 50.
    Aug 2014
    WI
    30
    Here is a picture of the shaft with a piece of piano wire under the sponsons. It looks like I am a little low. Worthwhile to try like it is or should I rework it before the trials this weekend?
    Mar 2013
    ny
    367
    that's what i was thinking
    Aug 2014
    WI
    30
    Sorry, no vids yet. New props did not arrive and the weather was not the greatest. Scrapped my teak strut and made an adjustable teak/aluminum assembly and raised the shaft axis a bit. All I have is a Proboat 2.05 pitch stainless and some unknown plastic props, probably in the 2.5inch pitch range by the looks of them next to the Proboat prop. Might try what I have Sunday 10-19-14 if weather permits. Will post vids if I run it, but will not have real speed info since I decided I could not afford the $150 with tax for the least expensive sportwatch GPS that my local Best Buy had in stock, especially since the GPS could go up in flames with the rest of the boat!
    Aug 2014
    WI
    30
    Project suspended. Water trials went poorly. Boat appears to be too bow heavy and appears to have too much torque for the length of the boat. The boat just spun in circles at low speed even with the rudder all the way to the opposite direction to compensate. Giving it more speed would let me get it going straight barely on a plane with strong opposing rudder, but when I would give it more power it would spin out and/or submarine. Lowering the prop shaft axis about 1/8 inch helped some, but not much. I don't think this project deserves more effort when suppliers such as OSE our sponsor offer such nice hulls. I have a 21inch monohull from OSE that just handles nice and goes like a bat out of 'ell. My son wants a big 29 inch Geico, but I am going to get a cat hull from OSE and paint it green and put a gecko on it instead.
    Aug 2014
    WI
    30
    2014-12-19-754small.jpg2014-12-19-752small.jpgProject has been brought back from the dead. I went over the water test in my head many times. The boat was way bow heavy with the ESC way up front. That ESC went into another boat, and I needed one with a low profile, so I used a Proboat 45amp I had in my parts bin. That went aft of mid-ship. Motor stayed the same, but prop is an x432 which I will shave down to about 29 or 30mm to better match the high rpm of the motor. I used the original rudder moved off to the starboard side but added a strut with a fin. I think it just might work this time with the balance better to keep it from diving, extra fin on the strut to help keep it from spinning out, and a real strut to allow for lowering the prop shaft. We have had some very mild weather up here in Green Bay, WI, so I just might get this thing water tested by newyears if I get my RC rescue/retrieval boat updated to version 2. That's a subject for another thread.
    Aug 2014
    WI
    30
    Quick update: cg issues resolved with new esc location. Boat planes easily and turns OK. Did a very short run in the Fox river after Christmas. I punched the throttle close to the dock and the boat instantly rolled over. Will experiment with smaller diameter props and adding turn fins, and flattening out the badly cupped right sponson, which I think is creating drag and making it roll over starboard at speed.
    Aug 2014
    WI
    30
    Default Update from 4-12-15 water trials
    I managed to get the boats out on the water last Sunday. The weather was not ideal, it was about 55 degrees with gusty 15-25mph winds that kept blowing my equipment off the pier toward the water. There was shore ice to contend with, and my 2 sons were at least as interested in playing '5 Nights at Freddie' on their tablets as helping me keep the equipment dockside.
    I made only 2 changes to the boat from my last update. I went with a smaller diameter prop to reduce the tendency to roll, and went to a 2S battery down from 3S. I made about 5 or 6 150 yard passes before the motor coupler came loose and I had to idle it in.
    The boat performed almost flawlessly. It planed off instantly, did not want to spin out, did not submarine, and did not roll or even lift one sponson. The turning radius was wide due to too thin of piano wire between the servo in the bow and the rudder. The wire would just tend to flex, rather than turn the rudder much. I didn't give it full throttle due to the fact that I had no human carrying rescue boat, and my rc rescue boat is still in early testing stage. But it did cruise nicely at what appeared to be about 20mph with no issues. I don't think I can fit my gps logger under the canopy, so I will probably have to rig some sort of external capsule for it. Once I shake the bugs out on 2S I will go to 3S and see what it will do. I don't know if it will still qualify as a mini anymore, since the distance from the bow to tip of prop nut is now 20.75inches! I will post a video after I figure out how to edit it down a bit.
    Once I have it tuned in, I will be happy to post all the specs if there is any interest out there.
    Aug 2014
    WI
    30
    Default May 17 water test with videos
    Well, a month has gone by since the first water test of version 3. Lets call this v3.1. 430 brass prop, 2s batteries, 1st run was 2/3 of a 3s that had a puffed cell that I removed, next run was with a Nano-tech 2s 1000mah. Going to saddle 2 of the Nano-techs next time. After running on Sunday I found they would slide down into the sponsons and I could parallel 2 if I wanted. No room for a gps, and I have not rigged up an external capsule for mine yet, so no speed results, just the video shot by my son CJ, the owner of the boat.
