Been doing some research about this question but found no definitive answer. I have a hornet f1. Basically only the hull is a hornet. Everything else was stripped. I added a 3650 2990kv 6d
On a os leg and a swordfish pro120a esc. I'm using 3s 4500mah 30-40c discharge batteries, the question is can I use 2 3s batteries in parallel to run the set up on 6s safely? Also I'm running a oct x438 prop, it's quick but I want it quicker. The temps are luke warm using it. What recommendation would be for the next few sizes to try to get where I want to be.
