I found a cool way to waterproof my receivers. I thought this up yesterday and couldn't wait to get home and try it. So...
I took the circuit board out of the case. Removed the decal. Drilled a hole in the top of the case.
Then I sprayed the inside of the case with mold release agent. Big piece of heat shink over the plug pins. Put the circuit board back in. Taped up the sides so the epoxy does not run out. Then poured epoxy in the hole. It turned out pretty decent. This was an experiment on a bad receiver. Now I know what better to do. Drill smaller hole and use a hobby syringe to force epoxy in to fill all voids. I'll be doing another one the better way soon.
