Results 1 to 4 of 4
Thread: Sexy SpeedMaster Trim Tabs
    Sep 2013
    On
    52
    Default Sexy SpeedMaster Trim Tabs
    Has anyone installed the SpeedMaster trim tabs? These are slightly larger in size(2inch) but will fit fine. These would require drilling through the hull with nuts and bolts though I believe? Any thoughts....
    http://www.offshoreelectrics.com/pro...d=ros-spdt-502
    Oct 2013
    TX
    1,060
    Can I assume you mean this one: http://www.offshoreelectrics.com/pro...d=ros-spdt-502
    They are nice But I like the new ones they just came out with... http://www.offshoreelectrics.com/pro...prod=ose-83020
    They are very nice but I would prefer the ones in my post (see second link). IMO tabs don't need to be as wide as some.
    Sep 2013
    On
    52
    Thanks for the correction. Yes those are the ones. I fixed the link. Do the new ones fit the factory holes?
    I might just go with the speedmasters. What's the best thing to use on the holes for a proper sealant?.. I heard GOOP is the best
    Oct 2013
    TX
    1,060
    I'm not sure if you have to drill new holes but probably.... If you were going to spend $50+ why not get the ones in the Spartan upgrade section? Then you could have 4!
    If you have a Marine Shop around call them and ask what sealant you should use. Maybe even shoo-goo would work for this?
