Results 1 to 4 of 4
Thread: Proboat A3630-1500 or Stock Revolt 30 motor?
    Sep 2014
    14
    Default Proboat A3630-1500 or Stock Revolt 30 motor?
    I have a basically brand new 1500 kv proboat (dynamite I believe) motor from a blackjack 26 basically brand new. Would there be any noticeable advantage to installing this in the Revolt over the stock Revolt motor?
    US
    5,557
    I wouldnt swap an 1800kv motor for a 1500, what advantage would that be? 1500 is too low for 4s to start with in my opinion. I believe the 1800 AQ motor is a 6 poler as well.
    Sep 2014
    14
    They are both 6 pole. I'm assuming the 1500 KV Proboat motor would allow me to run 5 or 6s provided I have the proper esc? I'm told the KV on the AQ Revolt is too high for 6s
    US
    5,557
    The 1800 will handle 5s with the correct prop.
