Results 1 to 9 of 9
Thread: Looking to purchase a good quality 28mm dia x45mm long bl motor?
    Jan 2011
    497
    Default Looking to purchase a good quality 28mm dia x45mm long bl motor?
    Hi all i have a Dave Frank Miss rock sport hydro hull length is 21 1/2'' beam is 11 3/4'' hull+ hardware+lipo=38 oz total weight the unfortunate part of this project is very limited interior space managed to sqeeze a Sea king 120 amp esc under front starboard deck im limited to a 2s 2500 mah 50c lipo in the battery tray and a 28mm dia x45mm b/l motor under the cowl . My goal speed wise around the 43 mph range. What kv rating would work? What brand of motor? Regards Andris Golts.
    US
    5,557
    Wow, you are limited in motor size. Too bad you cant get a 2858 or 2860 in there. Anyways, This motor would work well on 2s seeing as you have a huge ESC and plenty of amperage room.
    http://hobbyking.com/hobbyking/store..._Inrunner.html
    If you could somehow "find" the room, this motor would be the bomb.
    May 2014
    mi
    643
    I would go with this one in 3650kv
    http://www.offshoreelectrics.com/pro...o-2845&cat=148
    US
    5,557
    Quote Originally Posted by revoltrunner View Post
    I thought of that one too, surely the better choice but its 48mm long, wonder if he can "find" 3mm worth of room.
    9,398
    This is an awesome little motor but, too bad it's so pricey: http://www.greathobbies.com/producti...od_id=AQUG7005
    It's only 2200kv also so no room for more batts.
    9,398
    When I built several of these hulls 10 years ago I ran it in N2 Sport Hydro, it was a picklefork version, Atlas Van Lines...
    I made a dropped pan motor mount and mounted a Lehner Basic 4200 motor in it and 6 Nimh cells, esc was a Barracuda 80 I think?
    Is this the same thing you are building Andris?
    Jan 2011
    497
    Thanks to all for the great information .Ray the plans for the Miss rock came from 1991 US boat and ship modeler magazine . Regards Andris Golts.
    9,398
    Yep, same boat I built a few times. There are ways to fit stuff in....
    Nov 2007
    6,927
    I would look for something with 4200KV if only running 2S!
    Mini Cat Racing USA
    www.minicatracingusa.com
