Results 1 to 3 of 3
Thread: OSE Spartan Cable Upgrade Question
    Sep 2014
    79
    Default OSE Spartan Cable Upgrade Question
    Is the OSE upgraded Cable System (Strut /w bushings, .187" cable, & OSE coupler) a straight drop in replacement to the Spartan? Or do I need a larger diameter stuffing tube and Teflon liner?
    http://www.offshoreelectrics.com/pro...C-1405&cat=172
    May 2014
    mi
    643
    it says its a complete upgrade kit.
    take a 3/16 drill bit and stick the smooth end in
    your liner and see if there's a little room in it.
    that will tell you if it will work.
    Feb 2011
    AB
    775
    With the .187 cable you either run without the liner, or install a larger stuffing tube.
    I ran one Spartan for three seasons with a .187 cable and no liner without any problems. Just keep the driveline well lubricated.
    Kevin
