Dual Powerlab 8 vs Icharger 4010 Duo
  • Jdpb614
    • May 2014
    • 44
    The server supplies 2zo-rc can be used in series. If you check out this article you can see how many packs an I charger can do in on shot with correct power.
    What to look for in an RC Power Supply. Voltage & amperage are the main considerations, but what about growth potential?
    • kevinpratt823
      • Aug 2012
      • 1361
      http://www.rchelicopterfun.com/rc-power-supply.html
      I have actually been running a pair of those in series for over a year to power my current Hyperion charger, I already ordered another pair to set up in series. Each pair will run one side of the PL8x2 at 24v/47amps/1150Watts, and if I went with the Icharger 4010duo I would have just put all 4 in series for 48v/47amp/2300Watts. I get them on Ebay, this last pair was $32 for both, can't beat it. There are a few other models that work well also, but I already know how to mod/configure these ones so I stuck with the same.
      My private off road rc track
      https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
      • kevinpratt823
        • Aug 2012
        • 1361
        Off and running. Just charged (8) 5s packs from 3.7v/cell up to 4.2 in under 24 minutes! I'll post up a more detailed thread when I have time, but this thing is badass! :) I just need to build up a safer charge area now.
        Sent from my SCH-I535 using Tapatalk 2
        • MarkF
          dinogylipos.com
          • Mar 2008
          • 979
          Kevin
          You picked the right charger. If you talk to the company's who sell both chargers they will tell you the i chargers have a higher failure rate.
          Mark
            • 9488
            Originally posted by 785boats
            Sorry kevin.
            In my first post, I did mean to say highest balancing "current", not voltage.
            But I was referring to some of the chargers that only have a max of 200 or 300ma balancing current.
            I'm sure you'll be glad you went with the Powerlab.
            If Revolectrix bring out the 4.4 & 4.6V cells there will also be a firmware upgrade released unless they've already installed it up to those values in the newer chargers.
            Do we know when these new Revo packs are coming out??
            I need to get me a new charger for these HV packs that are out today
            • 785boats
              Wet Track Racing
              • Nov 2008
              • 3169
              I'm not sure. You would have to ask John at Revolectrix. All I know is that he was working on them. Might be a year or so.
              • kevinpratt823
                • Aug 2012
                • 1361
                Originally posted by MarkF
                Kevin
                Mark
                I actually did just that, and that is exactly what I was told. Thanks Mark.
                • dasboata
                  • Dec 2010
                  • 3152
                  #23
                  Hi Kevin are you really charging 8 pack there how do you keep track of the balancing on them ? thanks Chris
                  • kevinpratt823
                    • Aug 2012
                    • 1361
                    #24
                    parallel balance harness on each set of 4.
                    • T.S.Davis
                      • 6221
                      #25
                      Yeah me too. How's that work? Not questioning. Wanting to learn something. Your not the only one I've seen doing this.
                      Note on the iCharger.
                      My duo will balance two packs obviously. One of the gillion options on this thing is "regenerative discharge". If one cell is slightly high it discharges it a bit. With regenerative discharge on it pumps voltage back to the source. Sort of saving juice if you follow. So if charging form a battery it pumps power back into your car battery. Pretty slick.
                      You're supposed to turn it off if you are using a power supply as the voltage feed back to the supply will climb. Unfortunately, even though it's turned off, it still back feeds to the power supply until your power supply overvolts and shuts off or self destructs. I lost 4 power supplies before I figured out what it was doing. It's a horrible design flaw. My bulldogs will just reset themselves but charging stops as the charger shuts off and reboots. The computer type power supplies that are popular lately that go 75 amps don't have overvolt protection. They just die.
                      Noisy person
                      • roofintrash
                        • Aug 2016
                        • 48
                        #26
                        Thank you for asking the question that has made my bald spot bigger.
                        Rick
                        • T.S.Davis
                          • 6221
                          #27
                          I'm still confused by this.
                          So the charger is monitoring voltage for 4 cells for each one cell that it thinks it's monitoring. You could have one cell low and one high cell in the paralleled set but voltage reads to the charger like everything is golden.
                          Does this make anyone else's head hurt?
                          Noisy person
                          • roofintrash
                            • Aug 2016
                            • 48
                            #28
                            That's exactly what I was thinking. How does it know which cell in which pack is low or high.
                            Rick
                            • T.S.Davis
                              • 6221
                              #29
                              I want to know this too. I know others are using this approach to charging so if someone knows how this works please share. I'm ignorant and want to understand it.
                              Noisy person
                                Ahhhhh. This is why my power supplies were failing when using ichargers. When I switched to powerlab I didn't have any more issues.
