It looks like my thermal switches are arriving today. I might have to make a trip to the motorcycle store and see if they make a nice LED flush mount turn signal that looks like a hood scoop
--Albert Einstein
nice build rear... never have figured why aeromarine made the deck come down so low as to not let a rudder or strut fit flat but you did a great job fixing that for sure
My build thread is cursed !!!!
--Albert Einstein
Test
--Albert Einstein
Last post by you I see on my desk top is dated Sept. 15th, 06:34AM.
Test.... It looks like I can see recent things now !
--Albert Einstein
--Albert Einstein
Hey, now I can see you!
Cool ideas you have!
Thanks Tlandauer ! I figured on pulling all the stops with this one
--Albert Einstein
I don't think the pump "gets back" any power. Then again it could... They work great as long as you take there of them. I ran mine in salt and forgot to clean it after....
I hope the pump idea works well! Kintec has a new $55 pump, there are some on Ebay that look just like it though for less $...
Enough of that! This build is looking good so far!
My pump cost me $20 from swap shop . My local dealer sells them for $28 and they have several others to chose from for less $. it works perfect with the check valves when I did my test.
--Albert Einstein
--Albert Einstein
--Albert Einstein
--Albert Einstein
Some real cool ideas in this build, I am anxious to see how it all turns out!
Thanks J
--Albert Einstein
I like the lights , what are the blue cylinders for ?
They are 2.5 lb weights . There are pool noodles on the bottom between the sponsons under the motor area , the added weight made the JB push out the edges more uniformly .
--Albert Einstein
Ha ha !
--Albert Einstein
Why not just bolt the whole unit in from the bottom? that way it would have been removable for maintainance?
We call ourselves the "Q"
