Page 1 of 16 12311 ... LastLast
Results 1 to 30 of 475
Thread: Aeromarine Team Believer with updated hatch build. Special
    Oct 2008
    ca
    1,941
    Default Aeromarine Team Believer with updated hatch build. Special
    So I'm kicking off the Team Believer build with a plan. I'm starting with the motor mount. It's going to have a big motor on 6s
    --Albert Einstein
    Apr 2011
    5,666
    Nice work shop, love that aluminum mount! thread subscribed!
    Oct 2008
    ca
    1,941
    My shop is my apartment patio with a easy-up lol
    --Albert Einstein
    Oct 2013
    la
    8,740
    I'm anxious to see how this big motor is gonna do!
    Oct 2008
    ca
    1,941
    Default Motor plate
    This where things start getting interesting for me !
    --Albert Einstein
    Oct 2008
    ca
    1,941
    Something like this should be good. After the motor mount is done I will make a esc mount and servo mount both bolt to the aluminum rails. Kind of like a drop in system
    --Albert Einstein
    May 2014
    le
    58
    very nice
    Oct 2008
    ca
    1,941
    Thanks robw.
    --Albert Einstein
    Oct 2008
    ca
    1,941
    One of the things I do when designing things is make templates and keep them in case I want to make parts again.kind of like a jeweler I can fit the whole store in on bag.
    --Albert Einstein
    Oct 2008
    ca
    1,941
    8 taps comming up . I estimate this boat will need about 32 of them
    --Albert Einstein
    Mar 2014
    Ma
    1,951
    dont ask
    Oct 2008
    ca
    1,941
    Currently this may be the worlds biggest motor mount but it's not official yet lol
    --Albert Einstein
    Oct 2008
    ca
    1,941
    Quote Originally Posted by Luck as a Constant View Post
    dont ask
    All questions subject to answer , for now I will ask the questions if I need advice or act like I need help don't worry I will ask lol
    --Albert Einstein
    Oct 2008
    ca
    1,941
    So I shaved the bottom down on the V3 to get a look at there copper compound and to see if I could cool this esc even better since I'm running a big motor :)
    --Albert Einstein
    Mar 2014
    Ma
    1,951
    dont ask
    It had to do with my domination of the forum today.
    See this thread for your answer
    https://forums.offshoreelectrics.com/...ting-the-forum
    Oct 2008
    ca
    1,941
    So I figured I would JB weld it to an aluminum plate that will transfer the heat down the rails. I might ad a second cooling line to the plate.
    --Albert Einstein
    Oct 2008
    ca
    1,941
    I also will add be very carefully when cutting the bottom of the V3 . I'm pretty sure I did not damage it but had a close call. I seen sparks come of my band saw so I backed off sand took a smaller bite. Almost shaved off that deal that has 100 on it. It has hard metal in it what ever it is. I plan on putting power to it tommorrow for a peice of mind.
    --Albert Einstein
    May 2013
    426
    Looking good! Thread subscribed
    Apr 2013
    777
    Subscribed.
    I love the aluminum look. I curious why you decided to mix CF in with the aluminum.
    Oct 2008
    ca
    1,941
    Subscribed.
    Thanks, well the mix of the two is only based on my opinion of what works best on that particular part . My goal is max strength and function . For the motor mount plate I went with a 1/8" plate braised on 3/8 square bar so I could drill tap the side plates on, also aluminum here will obsorb additional heat and should i need to ad cooling lines to the plate I can although I don't think I will. The added cf to the plate was to increase rigidity and overall strength reducing some of the stresses to the welds. The cf side plates to save weight. Of course the aluminum esc plate to absorb heat and a cheap replacement should I fry the esc, it also is my tool to keep the rails aligned. I think both materials are superb in different area's
    --Albert Einstein
    Oct 2008
    9,488
    What KV is the TP ?
    Oct 2008
    ca
    1,941
    What KV is the TP ?
    1800
    --Albert Einstein
    Oct 2008
    ca
    1,941
    It's going to have a water pump activated by full left turns. Boat won't be moving of coarse .
    --Albert Einstein
    Oct 2008
    ca
    1,941
    This piece of indestructible lexan should make a nice platform for the pump system . It's actually the same or lighter than cf and non conductive, cheap in comparison too...
    --Albert Einstein
    Oct 2008
    ca
    1,941
    Just a bit of info.... The esc and engine part of the mount with both bolted is weighing 30.2 oz. . Not too heavy yet.
    --Albert Einstein
    Oct 2008
    ca
    1,941
    Bad news . I tried to braise some aluminum for the servo mount to the right rail thinking that would be lighter and ruined the right rail. Good new is I made a new one and a servo mount out of cf and I now have a rail template .
    --Albert Einstein
    Oct 2008
    ca
    1,941
    --Albert Einstein
    Oct 2008
    ca
    1,941
    Platform is getting there. After it's fully built I will break it all down and put the finishing touches to it. This thing is going to cradle everything and I anticipate more brackets , a interesting water plumbing system, the fun part !
    When it's all done I can get to the transom, this boat isn't kind in that area. After that battery trays made with lexan.
    --Albert Einstein
    Oct 2013
    la
    8,740
    Can't believe I missed all this progress! Looking good!
    2,731
    Does the Super X electric fuel pump, pump electrons back into the 1350mAh LiPo for unlimited run times?
