Originally Posted by
Kaotic
This time I used JB Weld which I believe Kfxguy uses for his motor mounts. It seems pretty solid now.
I do use jb weld and jb quick. It's strong enough to likely rip the hull. Who did the m645 prop? The m645 should be about 6mph faster (what I've seen anyway). You might be running out of motor. What I would do is put it on 5s but put about a 42mm prop. If you use an x642, make sure it's detounged. The reason I'm not telling you to run 5s on what you have is because you would potentially pick up about 10mph and I'm not so sure that hull would stay on the water at 73-75mph. If you want to stay with the prop you have, get a pair of 2s revolectrix batteries and you'll pick up at least 2-3mph. I've seen more myself.
