Results 1 to 7 of 7
Thread: BJ 29 Stripped motor bolt
    Aug 2014
    120
    Default BJ 29 Stripped motor bolt
    New to the FE boating. Just bought a new rtr and decided to epoxy the seams and wood so I removed everything in the boat I could. I guess I used a little too much muscle installing the motor back in the boat and stripped the nut that is in the motor mount. I don't really know what to do besides being mad at myself lol.
    Aug 2014
    120
    Nobody?
    Apr 2013
    38
    Cut a slot in the screw head with a dremel and back the screw out with a flat head screw driver.
    Apr 2011
    5,666
    Did you strip the blind nut that is under the wood?
    1,969
    Pour some epoxy into the hole and re-tap. Easy fix.
    Chief
    Aug 2014
    120
    Thats the one. does not tighten up.
    Aug 2014
    120
    Yes, stripped the nut.
