I say sell that motor, then buy two 4060's and two seaking 180 esc 's. If your going to run 4s in each sponson, get around a 2200kv motor. If your going to run 3s in each sponson, then run in series and then run the power to both esc's, use about a 1500-1800kv motor for each side. If you fo a single, I'd still sell that motor and get a higher kv. A 4060 1870kv on 6s will push it into the 70's. You could also do a 4070 150 kv on 7s.....my preferred combo would be 4060 1870kv, seaking 180. ...I just build a 32" cat with this same combo and it runs 77mph with ease and I did no tweaking to it. With a sharpened rudder and tweaked with good batteries, it would do 80+.
