Results 1 to 3 of 3
Thread: Longish battery leads, need caps? Swordfish 240/15271Y/6S Parallel
    Apr 2014
    77
    Default Longish battery leads, need caps? Swordfish 240/15271Y/6S Parallel
    Hi guys, wiring up my Phil Thomas 40 Roundnose (Swordfish 240/1527/1Y/6S Parallel) and I'm running parallel packs which necessitates ~8-10" leads from the battery to the esc. THE SF240 uses 8 gauge wire, I'm using 8 gauge wire for my parallel harness and the 8 gauge castle bullets. I know this appears long from my searching, but I don't have too many options to get the batteries in the right spot and to be able to disconnect it easily. Will be primarily used for sport, not racing so props won't be crazy.
    Thoughts?
    Apr 2011
    5,666
    Caps are always a good idea, but the total length should not be more than 10" at the most, than includes the wires from the ESC +battery leads.
    Just my $.02
    Cheers!
    Apr 2014
    77
    Just my $.02
    Cheers!
    Thanks TL
