I'm still learning myself but i'll tell you what i have learned. I have been doing lots of prop testing so this is my real world experience and not me just repeating what someone else has said.
Removing the tongue will give you more speed. i have not gone very far with it yet...as in remove much more than an M series just yet....I'll do some experimenting to see how far i can go soon. Having more tongue helps you get on plane faster....seems to be more helpful in a mono....
I havent has any problem getting on plane except with that octura 20 series prop. It took about 10 feet to get on plane and when it did...it turned into a plane because the boat would launch into the air out of the water. not cool.
What i suggest to you is doing the same thing im doing. Start slow. buy a few props to experiment with. buy a couple m series and practice turning an x series into an m. If they offer an x series and an m series in the same prop...buy both. make the x series match the m series in speed. Youll be able to tell what works and what dont. gps is your friend so you can see definate results and not guessing. Its takes time...and is a leaning curve but the outcome is priceless...you wont have to rely on someone else to do it for you anymore. Its quite fun too...except the retrieval part when you have a nasty prop that dont act right...lol
