Hi guys, this has been an interesting read. At the bottom of the planet here in NZ we don't have all these problems, fe is pretty small. The NZMPBA has E-ltd (cos the petrol heads got confused!)
Here is our class (offshore, hydro has same specs except hull)
LIMITED E CLASS OFFSHORE (14.8Volt Max)
MOTOR/CELL OPTIONS
a). 12 cell Ni-Chemistry 14.4Volt or Li-polymer batteries (Lipos) 4S1P 12000mah max or 4S2P
12000mah 14.8Volts max.
b). Power in this Class will be brushless motors with a maximum can size of 36mm
diameter x 75mm in length (in-runner). Motors not allowed in class Neu, Hacker,
Mega, Aveox, Lehner
Motor Controller is open
c). Ready to run boats (RTR) Aqua Craft SV-27 and Pro Boat
d). Offshore hulls must be a Deep-Vee (16 to 28 degree “V” angle), or Offshore Catamaran type hull.
e). Freeboard, as measured at the tallest point on the side of the hull, will not be less than 25mm.
f). Stepped hulls and flat keel ride pads will be allowed on both Deep Vee and Catamaran type hulls.
g). Closed cockpits must have windshields. Windshields can either be clear, tinted or coloured.
Open cockpits must have drivers.
h). All efforts should be made to colour and number hulls in the spirit of real offshore racing.
However, this class is intended to be stand-off scale class.
i). Safety Loops and isolating switches are
mandatory.
j). No gear boxes allowed
k). NZMPBA electric class racing rules will apply (4 laps max)
l). Minimum hull length 24 inches. (610 mm)
I know that it doesn't have any effect for you guys(perhaps going off on a tangent even), but my Pursuit running a TP motor (fits this class) took out our club high points and mono racing all year against petrol and nitro boats. I've been going it alone but now have an Impulse and shortly a Smashshark to race against. It has been quietly amusing to beat the petrols but even better buzz to help get new boats up and going. I have changed to a 40mm can motor (TP again) as the boat runs better and I can utilise more props and get even better speed. As Nz Pres. (with the commitee) I will be doing an overhaul of our electric classes in the near future as this will go in hand with the work we are doing with the other power modes. Due to the small number of boaters racing in NZ I am looking to simplify things down to 2,4,6 cell setups and take off the motor restrictions that exist, this should be sufficient for the next few years and line up with some of what is already happening north of the Bombays (only Kiwis will understand) and will hopefully encourage some of the fractionation that does exist here to mend a bit. Well thats the dream anyway!
Just thought I would chuck this in.
If any one is intersted have a look at www.nzmpba.co.nz
BTW I run on a near nonexistent budget!
