Page 1 of 2 12 LastLast
Results 1 to 30 of 56
Thread: prop shape help....
    Oct 2013
    la
    8,740
    Default prop shape help....
    I have an m645 prop that just kicks every other props ass. No matter what. I just did an X646 to try and beat my m645. Nope. It's about 4 mph slower. I detounged the crap out of it but maybe not enough. I tried an abc 1816 and it was horrible. Think I screwed it up anyway. Not worried with that one, it ended up at like 41 mm cuz I slipped on the belt sander lol. Anyway, look at the tongue difference. Should I cut the X646 down even more like the m645? M645 on right. X646 on left and abc on the rear.
    The X646 is just much nicer and you can tell it's thinner. Just more tongue.
    7,629
    I would put a piece of masking tape over the M645's leading side and trim it to the outer shape, then pull it off and match it up on the 646. Make sense Trav?
    Oct 2013
    la
    8,740
    Excellent idea! Thanks!!!
    7,629
    Also works well to copy for reverse rotation such as say,,, 447's.
    You can use the trailing edge and hub of prop as the reference guides.
    Just where I came up with it. Oh and of course, balance after
    Jul 2007
    or
    1,088
    That M645 looks like it may have some extra cup bent in the TE. If so, the x646 will have a hard time keeping up.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
    Jun 2011
    ct
    826
    Quote Originally Posted by raptor347 View Post
    would it be a good idea for kfx to cut the 646 to the exact blade size as the 645 and remove cup if any then run? whats his next move if the 646 is slower than 645? is he rapidly approaching his boats max speed? this a good thread as kfx is putting alot of effort into this project and everyone can learn from the experienced boater's input.
    Removing cup will slow the boat...just the opposite of what the OP wants. Matching the exact blade area is less important than increasing the TE cup. Otherwise he is simply duplicating the m645 (with a tiny bit more root pitch), what's the point? Get a pair of jewelers pliers and bend in some cup.
    Jun 2011
    ct
    826
    Default prop
    he said he lost 4 mph with the 646. then someone said the 646 had more cup than the 645. so wouldnt cupping the 646 increase the load, slowing the boat even more?
    Read Post 5 again, the m645 has more cup added. That is probably why the x646 is slower. That, or he tested the props under different conditions. That alone can cause a 4 mph difference even with the same prop...
    7,629
    Just a light chop can really break a boat free. That can come from just a good sudden breeze over water.
    As big a difference is battery condition. A 100 degree battery will put out more voltage than a 75 degree battery will. Testing a prop with a battery fresh off the charger then comparing it to one with a battery half discharged can mean a difference of a volt or more....why bother. I see many folks making these mistakes every day, getting meaningless "data" and often choosing the wrong prop or strut setting because of it.
    Oct 2013
    la
    8,740
    I made several passes with both props. Swapping back and forth between the two. I went the same direction every time. I put the m645 on, made one pass. Brought in. Checked speed. Swapped prop to x646, made pass. Brought in. Checked. Slower. Put m645 back on. Made pass. Check. Back to where it was on the first run. X646 back on...you get the picture. I'm not sure how I could be more consistent. The X646 runs 78.something every time and the m645 run 82.something every time. I thought it was a consistent test?
    Wait, 646 or 648? Now the OP says both...typo? No one said the OP's testing was not done well, just that no one knew. It sounds like very good methodology to me. The difference is likely the lower thrust from the larger prop compared to the cupped 645. Forget blade shape and bend in some cup. Blade thickness matters too.
    Oct 2013
    la
    8,740
    Sorry about that. Auto correct on my phone has the 648 stored lol. I didn't go back and fix it. Just for clarification I'm testing the X646 vs m645 back to back. I looked closely (the pic fools you, the X646 has a touch more cup, thinner and a bit more tongue. I'm reshaping it like the m645 to see if that helps.
    Oct 2013
    la
    8,740
    Here's how much I had to take off....
    Oct 2013
    la
    8,740
    Here's the results. The newer looking one is the X646
    Jun 2011
    ct
    826
    Default prop
    looks good. did you use masking tape to trace 645 blade and transfer to 646?
    Oct 2013
    la
    8,740
    Quote Originally Posted by urbs00007 View Post
    Thanks! Yes, that's what I did.
    Oct 2012
    1,136
    Travis, very nicely done brother...Fluid had a very valid point...try testing with fresh charged each run...even just a short run can make a big diff, specially when your trying to get just a few mph more....DJ
    Oct 2013
    la
    8,740
    Quote Originally Posted by olwarbirds View Post
    Thanks!
    It would be impossible to charge in between runs. I'm riding out to a lake in my atv.....
    But, I've run 82.xx with the m645....swap props....79.xx....swap back to the m645...82.xx again.
    Oct 2013
    la
    8,740
    Another one I just did.
    Oct 2012
    1,136
    Travis, looks good, Ive got one of those cut down a bit (48mm) cupped/detounged/backcut and I just finished a s/b/thinning on it...to be honest I'm still a bit leary about thinning much...on a 45mm that was just s/b I was getting esc temps around 130 ....so not sure if I should try that worked x450 on that setup or not...least not till I do the seperate cooling upgrade....DJ
    7,629
    Good work there Travis. Now to test.
    Oct 2013
    la
    8,740
    Well this one is for someone. He told me try it if I want before sending to him.
    7,629
    You know, of all my prop tests on the Miss Behavin' Geico, the 645 has been most consistently best. Have an ABC that is good at speed once it stops cavitating, but it falls off in the corners.
    The 646 is defiantly a cleaner cast to start with.
    Oct 2013
    la
    8,740
    aint no doubt about that. thinner than the m645 just has a tongue. The abc i tried cavitates like a mofo, grabs and then jumps nthe boat out the water. yea....im not into that. Id rather not have to recover it every other pass. Ive been quite lucky. Ive yet to have a blow over.
    Aug 2013
    Fl
    2,451
    Don't say that too loud..... "Blowover"
    Oct 2013
    la
    8,740
    Quote Originally Posted by flraptor07 View Post
    Well.....I may this weekend lol. It should go a little faster!
    Aug 2013
    Fl
    2,451
    BTW the props look good! Ya know blowovers mean one of two things, (1)either your setup is wrong or (2) you're on the ragged edge of that hull going as fast as it can go. I'm thinkin' you're headed for #2 cause you wouldn't be going as fast as you are if your setup was wrong..
    Oct 2013
    la
    8,740
    Maybe so....I have some ideas on how to counter act that tho....hopefully. I'm heading to the lake shortly with a small arsenal of props to try lol.
