... and... at least by my reading of the rules, P-OPC and "T-OPC" (open) can run "Any amount and/or size
of motors" (That's copy and pasted directly from the rulebook)...
So... are we going to see that TWIN P-OPC when you are here??
Darin E. Jordan - Renton, WA
And it is not just twin motors allowed but any number of motors. One racer showed up with a 4 motor conquest. He did have to use only 2P maximum though under our rules.
TG
Tyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
Actually, the rules don't say that... We don't have paralleling limits any longer.
What they say is that you are allowed a maximum amount of mAh... 10,000 for P and Q, I think 12,000 for S and T... You have to distribute that across the motors how ever you please.
For example, with two motors in P, you can either power both together by a single ESC and 10,000 mah@14.8V, or by 2 ESCs with 5000 mAh each @14.8V.
I need to go back and read, but there might be something in there about how one can divide up Voltage across the motors as well, but I don't recall exactly.
Bottom line would be that you can't have more than the maximum amount of allowable mAh on board when running the maximum class voltage.
The guy with the 4 engine cat had 4 - 6s 2500 packs. One for each motor. Having such small packs really hurt any chance of getting any records. I ended up beating him with my mono.
Mark
it was actually worse than that , I had 4s series into 2s x2 . They were 5000mah Turnigy 40c , instead of making a battery splitter I just took the esc's and paralleled them by soldering there battery wires together . If I only had the new thunder power batts I would have had a chance
--Albert Einstein
I new somehow you only had 2500 mah going to each motor. I would have liked to see that boat run on 4 5000 packs. 1 to each motor.
Mark
I tried. I ruined 3 of my packs that day.
--Albert Einstein
impressive speeds gents, congrats to all participants.
