Page 2 of 12 FirstFirst 1234 ... LastLast
Results 31 to 60 of 331
Thread: 80+ mph 32" rivercat
  1. #31
    Oct 2012
    1,136
    Travis, to run 7S or 8S in the T180v2 you have to turn off the LVC and add capbanks an external bec wouldnt be a bad idea either. Another nice build bro... DJ
    PS: set lipo to auto detect
  2. #32
    Aug 2013
    Fl
    2,451
    Stainless
    Cool, I like the stainless better myself. They are harder to work with but the end result is better and they are stronger..
  3. #33
    7,631
    Quote Originally Posted by MarkF View Post
    kfxguy
    If you want to go fast try the abc line of props. Maybe a 1816 for starters.
    Mark
    And get Chris(Dasboata) to 'do one up' for ya
  4. #34
    Oct 2013
    la
    8,740
    Quote Originally Posted by flraptor07 View Post
    I wanna try something different so I figured I'd order some stainless ones. I won't be getting the 225 Prather tho. Ose is out of stock so I ordered them from kintec, he refunded me for the 225 a day later. Guess he didn't have them. I just bought an etti 7s 150 amp pro race controller and three more batteries....2 3s and one 4s pack. All 6500mah 65c. They are spc packs, I seem to be having good luck with them. They are constructed well and have noticeably more power than my venom. I already have a set in my possession that belong to my buddy and I've compared them to venom in my buggy. I expect just the batteries to pick up a mph or so. I'm gonna sand the bottom bur I'm unsure what grit...600?
  5. #35
    Aug 2013
    Fl
    2,451
    600 or 800 will be good....
  6. #36
    Oct 2013
    la
    8,740
    Quote Originally Posted by olwarbirds View Post
    Update: this worked like a champ. Thanks! Now I can run it on 7s. I have a problem tho. A 4s pack will not fit no matter what.
    I ended up using a loose matching cell and added it in. I put it in against the wall to the outside left of the boat, velcroed in place. Then the 3s pack gets strapped in essentially sandwiching it in there. I'm tempted to go run it tomorrow. Bad thing is I just ordered a $85 4s pack I can't use. I even cut the side rail thinner. Nope.
  7. #37
    Oct 2013
    la
    8,740
    I upgraded the cooling on the esc also, figured it could use it. (Most of you saw this in my other thread so sorry for the repeat. Just wanted to document what I've been doing)
  8. #38
    Aug 2013
    Fl
    2,451
    Default Cut Hatches
    Travis, you really want to get slick? Cut some new hatches up forward over the sponsons to slide your 4s packs in, like the ones on this Hydro.DSC02578.jpg
  9. #39
    Oct 2013
    la
    8,740
    That's pretty slick...and I could do it but I got it working now. I think if I put batteries that far up front, she'd submarine when I let off lol. It's also full of foam up there too so that would be a mess! I'd rather just build another boat
  10. #40
    7,631
    ESC looks good in there Travis. You're becoming a CF king. Hehe
  11. #41
    Oct 2013
    la
    8,740
    Update:
    Had intentions of trying it on 7s. I forgot my Y adaptor so I'm topping my packs off. I did a little back to back battery testing.
    Test 1. Prather 230 prop. Strut unchanged from 70.0mph run. Venom 5000 50c packs. Well broken in. These packs balance perfectly every time. Result:
    Test 2. Spc 6500 65c same everything as above.
  12. #42
    Oct 2013
    la
    8,740
    Btw, esc temp was 110f and motor was 118f. That was after making several hard passes and running around the lake for a bit. When I ran it more it didn't really climb higher. I did not revert back to the stock cooling block like I wanted to. Before the block I made the temps were 109 - 110f with less prop. The motor temps were about even with the esc temps. Now esc temps are staying lower. I guess the block helps. Doesn't hurt that's for sure.
  13. #43
    Oct 2013
    la
    8,740
    Went back just now. Ran on 7s. Hoped to pick up 8 to 10 mph but it didn't. Still a gain tho! Surpassed my goal...wooohooo! Video shortly
  14. #44
    Aug 2013
    Fl
    2,451
    There ya go Travis, I knew you'd get that 80 mph. Now let's see 90 mph!
  15. #45
    Oct 2013
    la
    8,740
    I thought it was gonna do a little better with the Prather prop. It's thin as can be and it still prop walks. The m645 don't prop walk. I dunno. What prop should I try next? I know if I get a match 7s setup in the spc batts it's gonna pick up 1-2mph but I'm not sure on what prop to try next.
  16. #46
    Aug 2013
    Fl
    2,451
    Get a X648 detounge, thin and balance it, and see how that works. Did you detounge the Prather?
  17. #47
    Oct 2013
    la
    8,740
    Not too much. I'll post a pic of it tell me what you think.
    Here's a video.....
    http://youtu.be/smPNV-VKkQ4
  18. #48
    Oct 2013
    la
    8,740
    I'm sorry guys, I got ahead of myself. I forgot to show what it did on 6s, still pretty fast. I just got so excited about the 80.6 on 7s I forgot how good it did on 6s.....Prather prop. May have went a touch faster with the m645
  19. #49
    Aug 2013
    Fl
    2,451
    If you totally detounge the Prather it will take a lot of the prop walk out, and if you get the X648 do the same with it.
  20. #50
    Oct 2013
    la
    8,740
    10-4....will do that before next run. Thanks!
  21. #51
    859
    Wow. Very nice. Congrats man, lets see more!
  22. #52
    Oct 2012
    1,136
    Nicely done Travis. Kind of strange the m645 dont propwalk but the prather 230 does not much difference in them other than a slight pitch 2.8/3.0...I guess at those rpm's that little bit could make the diff....one of the reasons I go smaller props higher kv motors, no propwalk...looking forward to seeing what the detounging does...DJ
  23. #53
    Oct 2013
    la
    8,740
    Thanks. I'm pretty stoked but I know she's got more in her. I'm really wanting to try a neu 1521 tho. I think it'll be a little fast on 6s. Here some pics of the two props. You can clearly tell the m645 is thicker too....
  24. #54
    Oct 2013
    la
    8,740
    Last one...
  25. #55
    Jul 2010
    3,663
    ABC 1816
    Congrats on 80mph!
  26. #56
    Oct 2013
    la
    8,740
    Quote Originally Posted by keithbradley View Post
    ABC 1816
    Congrats on 80mph!
    Thanks! I'll check into that prop. Cant hurt to try it.
    Edit: I see the 1816 is 1.6 pitch....same as I have now. ...is it just a much better prop? Or maybe go with the 1.8 pitch version?
  27. #57
    Jul 2010
    3,663
    You could try both, but don't put too much thought into comparing the numbers. ABC props will typically perform (and load) to a higher degree than other brands with similar pitch and diameter numbers.
  28. #58
    Aug 2013
    Fl
    2,451
    Last one...
    That little bit of back cut should help a little too, you might want to put a little more in it. I'm trying to remember what style of back cut they call that...
  29. #59
    Oct 2013
    la
    8,740
    i'll try that. im also going to order a prather 235 and cut it down and detounge it. ill order an abc prop too.
  30. #60
    Oct 2013
    la
    8,740
    thats the info i was looking for. I'll try one..thx.
    Anyone have a 1521 neu they wanna sell????
