Results 1 to 6 of 6
Thread: ul-1 going through esc's and bec's
Hybrid View
    Jul 2011
    bc
    16
    Default ul-1 going through esc's and bec's
    hi,
    I have a ul-1 with a leopard 3674 2200kv motor with a 120a esc and running stk prop with a pair of turnigy 40c 5000mah batteries. I was running 30c 5300mah gens ace batts but they were getting really hot so I tried the turnigys and they run a lot cooler but now the capacitor on my castle bec is popping and the caps on the esc are starting to bulge. I have gone through 2 esc's and 2 bec's. do I need a bigger esc? are the bats to big? could this motor be pulling that much amperage? any advice is appreciated.
    thanks
    AZ
    8,010
    That motor is quite a bit hotter than the stock motor, it could be pulling a lot of amps. The stock prop could be too much, I'd opt for a 'smaller' one. The boat may be running too wet or there could be a bind in the driveline. How you drive makes a difference too - lots of on and off the throttle, running until the LVC cuts in, all increase heat.
    Jan 2008
    VA
    3,070
    In ref to the batteries being too big. The packs are only going to give the motor what it asks for. Higher quality packs with better output will deliver a bit more amperage but will only push your gear over the cliff if it's running on the ragged edge to begin with.
    Jul 2011
    bc
    16
    Thanks guy's, do you think that a 120amp is on the small side? Should I move up to a 180amp? I am on and off the throttle a bit cause the pond is not that big but I don't think it is running too wet.
    Mar 2014
    Ma
    1,951
    The timing should be 5 degrees or lower. Dunno where your timing is set
    Jul 2011
    bc
    16
    Timing set to 3.75 degrees
