Page 2 of 5 FirstFirst 1234 ... LastLast
Results 31 to 60 of 123
Thread: thrust bearing.....what's your take?
  1. #31
    Oct 2008
    ca
    1,941
    --Albert Einstein
  2. #32
    Mar 2014
    Ma
    1,951
    Default thrust bearing.....what's your take?
    Quote Originally Posted by rearwheelin View Post
    Yesway
    I don't know how anyone could come to any other conclusion. Just based on physics this seems to be the only plausible theory
  3. #33
    Jun 2009
    2,536
    You guys that run a thrust bearing at the strut, what do you do with the cable contraction?
    Been stewing on this a couple days.
    It is an interesting line of thinking that Mike was eluding to. The thrust has to be actually transferred into the body of the boat somewhere. My brain is thinking that transfer happens in one of three places.
    At the motor: This would mean that the stuffing tube was relatively straight and there was a gap at the drive dog. This does have a risk of flex shaft whip. There is also a risk of actually knotting up the cable if it's off a tick or if the gap at the coupler is too large. If the transfer is happening at the motor then the pressure is applied at the motors tail bearing or if the tolerances were just right on both bearings. Or....you place a thrust bearing between the motor mount and the coupler. Pressure is then placed on a bearing designed for pressure transfer.
    In the stuffing tub: This is either a nice smooth J or S bend. So the transfer happens where the flex smashes itself into the side of the tube as the prop pushes it forward. Makes the transfer between two pieces of metal or against the teflon liner. This is the most common I would guess. Down side, it feels like we get a relatively small pressure point. I don't know exactly what that looks like. It may be that transfer happens the entire length of outside bends in the tube. If you follow. Works 99% of the time though.
    At the strut: Requires a thrust bearing or washers at the strut. You still have a J or S bend but only need just enough to stop any flex cable whip. Not sure what happens with cable shrinkage though. Hard to imagine it just doesn't happen.
    It's pretty easy to argue that having a thrust bearing or not depends on how you built your boat. Only you are going to know if you have a mild J bend and have thrust at the motor. For anyone to say "you gotta have it" or " you don't need a thrust bearing" isn't really fair. You have to look at the boats build and take your best guess if you need one.
    Wow...awesome summary.
    So I was talking to one of the gas guys last year and they claimed to have gained a couple mph by moving the thrust point to the strut via thrust bearing (bearing behind the prop). Sliding square drive at the motor allowed for cable contraction. The advantage is that you reduce the friction loss due to the flexshaft pressing on the stuffing tube wall while transferring thrust (Terry's second paragraph above).
  4. #34
    May 2012
    940
    I am not a record setter but have run RC boats since 1972. Having fun and learning all the time. I have noticed that with the thrust bearing mounted at the strut/propeller, using either a steel 3/16" shaft bearings one each end and with an extra support bearing installed 1/3 of the total shaft length. The third bearing reduced the shaft oscillation or whipping. When I used the cable drive the boat would settle and recover its position (boat position) better every time. No big deal but I notice little things like that. Overall speed the same wish I had GPS in the 70's Ha. I am using a wire drive now now on a new 24" long boat ECO V.2 Merlin with self righting. The wire is up against the motor shaft to set prop end clearance by the boat designer very simple. K.I.S.S.
    Sorry I had to add to tell the whole story. People that have known me for years tease me and say OK Caruso what is the whole story. Ha
    Nice to have friends that can tease you and you them.
    A lot of Knowledge on OSE and guys thanks for sharing as one who really appreciates the time that you take to reply. And to all the people who have told the story not only once but the same answer many times over......to help a new person.
    Last edited by Mike Caruso; 02-21-2015 at 05:02 PM. Reason: bearings one each end and 02.21.2015
    Do It Like You Mean It .....or Don't Bother
  5. #35
    9,398
    Brian Buaas(sp) knows the benefits of this type of setup. Seen his boats with this setup at the Nats.
    Quote Originally Posted by Shooter View Post
  6. #36
    Oct 2013
    la
    8,740
    Quote Originally Posted by Luck as a Constant View Post
    It seems to me all the forward force delivered by the prop is directly transferred to the motor, since the only thing keeping the cable from sliding in and out IS the motor, and therefor, that energy is transferred thru the motor mount to the hull. Essentially the motor is using the mount to drag the boat thru the water...
    At the motor makes most sense to me
    Think about this tho....when the prop is pushing on the cable, it's bunching up in the stuffing tube (more on this in a sec) and its contacting it in different spots adding drag that we normally don't think about. It's probably not much but it all adds up. Then it pushes at the motor. Some motors I have bought have a spring washer at the rear bearing. They break because (well I've had some break) because of the flex pushing on it. So what I've done is move the spring washer to the front instead. That solved that failure point. I have an idea that I've not yet tried. I was going to form my stuffing tube. Then cut some 1/2 "bearings" out of the next smaller size brass and solder them in every couple inches to help guide the shaft straight. May be a bad idea, may be a good idea...won't know till I try it.
  7. #37
    Mar 2014
    Ma
    1,951
    I dunno if you're agreeing with me or not Travis..?
    Either way, i stand firm on my theory. Regardless of any other small areas of resistance .
    Just trace where the majority of the props thrust is converted to.
    Better yet, if you didn't glue down the motor mount, short of the motor just spinning and thrashing about in there, would the boat really go anywhere?
    The whole drive would just slide up into the bow until the prop or motor caught s point it couldn't move forward anymore and then the boat would move forward
  8. #38
    Jul 2010
    3,663
    Oh boy...
    I just noticed this thread and gave it a quick read.
  9. #39
    Mar 2014
    Ma
    1,951
    Quote Originally Posted by keithbradley View Post
    Oh boy...
    i didn't think anyone was outta line... unless i am?
    its one of those subjects that will never be fully agreed upon until theres hard evidence towards one..
  10. #40
    Oct 2008
    ca
    1,941
    I have always ran the the Teflon octura washer stack for thrust . They last a good while and never fail . They don't seem to have much friction when pressing the dog against them and rotating the prop on the bench once they have a run on them with some sort of lubricant. I build my stuffing tubes as a guide for the flex rather than a place to absorb thrust forces . The whipping of the flex is only amplified when thrusting with the flex. I have seen some big failures from Teflon over heating and grabbing the flex destroying setups . Some of the best running boats I have seen thrust with the flex so bottom line is it's build skill and understanding what you are doing.
    --Albert Einstein
  11. #41
    Jul 2010
    3,663
    No, it's just interesting to see some of the stuff that gets tossed around in these types of threads.
  12. #42
    Oct 2008
    ca
    1,941
    Here is a pic of a flex thruster gone wrong. See the post here .
    https://forums.offshoreelectrics.com/...752#post291752
    --Albert Einstein
  13. #43
    Mar 2014
    Ma
    1,951
    I suppose if you have no gap at the strut, and the thrust washer were between the drive dog and strut tightly then the force is then put at the strut?
    Also, the square drives ... The prop and Teflon washer seem to ride against the strut. I guess there too the forces are put at the strut?
  14. #44
    Mar 2014
    Ma
    1,951
    Thinking about it now... The point where all the forward moving force is contained, could be transferred to different spots depending on where the thrust bearing is placed?
  15. #45
    Oct 2008
    ca
    1,941
    That's correct. .5 mm gap is good never tightly ! I check the shrinkage by putting a wrench on the collet and turning the prop forcefully with thick leather gloves . The flex don't shrink much at all ! In fact every flex I have used there is a inner and outer winding that wrap in opposite directions so it resists shrinking !
    --Albert Einstein
  16. #46
    Oct 2008
    ca
    1,941
    No. That would depend on your strut adjustment . Now , running a gap yesway. If you have your motor angled down in the front of the boat and your thrusting with the flex watch it go nose down.
    --Albert Einstein
  17. #47
    Mar 2014
    Ma
    1,951
    Are you proposing that the motor angle will affect the ride of the boat?
    I can see that
  18. #48
    Oct 2008
    ca
    1,941
    Yesway. Also the gyroscopic effect of the motor .
    --Albert Einstein
  19. #49
    May 2012
    940
    Ray,
    You are correct. I have finally realized (admitted to myself) that I am not a hull builder at all. So I talked to Grim and asked if he knew anyone with a Rigger for sale. Happy to say he did and I bought one of Brian's. It was run 2014 at the Nat's and I am lucky for it to be in my home in Chicago, IL now. Plans are to run at Flint, MI this spring. I cannot wait until spring.
    Mike
  20. #50
    Oct 2013
    la
    8,740
    Motor angle affect what?
  21. #51
    Oct 2008
    ca
    1,941
    Yeah think about it ! lol
    --Albert Einstein
  22. #52
    Oct 2013
    la
    8,740
    I have. No matter what angle the motor is at, it not going to affect it. The prop shaft angle is what will affect it. Think about it. You could face the motor backwards. It's still going to do the same thing. The prop and shaft are pushing it straight ahead. All you need is something to stop the shaft from traveling to far in the boat if you will (collet/motor) and no matter what angle you have the motor at, your going to have forward thrust dependent upon prop angle.
  23. #53
    Oct 2008
    ca
    1,941
    Very true.
    --Albert Einstein
  24. #54
    9,398
    You are pretty lucky to have one of his boats.
    Quote Originally Posted by Mike Caruso View Post
    Ray,
    Mike
  25. #55
    Apr 2011
    5,666
    Would it be more or less correct for me to think in the following way?
    As said from one of the posts, if the prop is pushing the boat, that kinetic energy is transferred through out the drive line. In a typical one piece flex cable where there is a gap between the drive dog and the stinger/strut, the forward thrust then is compressing the cable ( never mind the negligible shrinkage that everyone talks) , which in turn is transferred/relayed to the collet, motor shaft, bearing, endbell, finally to the motor mount which fortunately is secured to the floor and thus pushing the boat forward.
    So, if we push a car from the rear, we push the bumper or the lid of the trunk, can't imagine we will open the driver's door and push( pull) the car by the head-rest on the seat. With this logic, the two piece shaft makes most senses because you can place a thrust bearing between the stinger/strut and the prop (or without it like TFL setups) and that would serve as the rear most point to push the boat.
    In light of the usual set ups, since it is recognized that the cable does shrink, no matter how little it is, the torque that is causing the shrink is still greater than the pushing force that can compress the cable, and because of that, we don't have excessive cable whip.
  26. #56
    Oct 2008
    ca
    1,941
    So the u bend stuffing tube going to the reverse motor is now the thrusting point which means it will push the boat at the apex of the bend . If your u bend is high up it will try to lift the bend if it's low it will push more evenly. A thrust bearing at the strut would eliminate any negative handling effect of a stuffing tube like this. Just saying !
    --Albert Einstein
  27. #57
    May 2012
    940
    Yes Ray, The building job is soooo nicely done very talented man. Ice all around me so taking my time getting things ready. Boxed up Revolts and stuck them on the shelf. Real test is see how I do in the drivers seat. Mike
  28. #58
    Jul 2010
    3,663
    I usually push cars from the driver's door with the window down so I can steer. Otherwise you might run in to something.
  29. #59
    Jul 2010
    3,663
    yesway
    Were you recently bitten by Dana?
  30. #60
    Mar 2014
    Ma
    1,951
    :yesway:
