AQ ESC being used with Futaba 3GR-2.4G and two Hitec HS-5645-MG sevo's
Oh Heck I found this http://www.offshoreelectrics.com/wiring.php but still not sure. I think I found it.
Hi Folk's,
I have looked around and did not find the answer. First time I am doing this modification. I read the servo's pull a lot more current so I should add a BEC battery pack. Not sure what wire to cut off AQ ESC 60 AMP and then plug into the Futaba RX. I am using a new Revolt 1800kV motor and 60 amp ESC with 4s I put it in a MickieBez Jet pump boat. I have a new LIFE 1300 mah BEC battery is that good enough?
Thanks for reading.
Mike
P.S. Have a safe 4th.
Reason: http://www.offshoreelectrics.com/wiring.php
Do It Like You Mean It .....or Don't Bother
