Results 1 to 1 of 1
Thread: AQ ESC being used with Futaba 3GR-2.4G and two Hitec HS-5645-MG sevo's
    May 2012
    940
    Default AQ ESC being used with Futaba 3GR-2.4G and two Hitec HS-5645-MG sevo's
    Oh Heck I found this http://www.offshoreelectrics.com/wiring.php but still not sure. I think I found it.
    Hi Folk's,
    I have looked around and did not find the answer. First time I am doing this modification. I read the servo's pull a lot more current so I should add a BEC battery pack. Not sure what wire to cut off AQ ESC 60 AMP and then plug into the Futaba RX. I am using a new Revolt 1800kV motor and 60 amp ESC with 4s I put it in a MickieBez Jet pump boat. I have a new LIFE 1300 mah BEC battery is that good enough?
    Thanks for reading.
    Mike
    P.S. Have a safe 4th.
    Last edited by Mike Caruso; 07-03-2014 at 01:18 PM. Reason: http://www.offshoreelectrics.com/wiring.php
    Do It Like You Mean It .....or Don't Bother
