Hi all recently purchased 3 Seaking 120 amp esc's set timing at 3.75 degrees on all 3 of the esc's # 1 set up on 4s in a 30'' Dunlap tunnel hull Feigo 9xl turning a x637 prop? #2 set up on 4s 26'' Matrix outrigger with a Leopard 3674 1900 kv turning a x442 prop ? #3 set up on 2s in a 22'' mono running a Feigo 7s turning a x632 prop. Should timing be set different from the 3.75 degrees ? Regards Andris Golts.
