Results 1 to 3 of 3
Thread: Tighten Prop
    Jan 2011
    MO
    33
    Default Tighten Prop
    Finally got around to installing a receiver and testing my mini eco and noticed that prop was spinning back when I let go of the throttle. I had just hand tightened to test every thing. Besides putting some locktite on it, is there any other tips to tighten it down? There does not appear to be enough threads to put a nut behind it.
    Oct 2007
    1,302
    Sounds like maybe your drive dog is too far out? Do you have a pic of this?
    Nov 2007
    6,919
    There is no drive dog on the ECO's. It is a 4mm threaded shaft and prop threads on. You must use loctite on them!!
    Mini Cat Racing USA
    www.minicatracingusa.com
