Results 1 to 6 of 6
Thread: 6S can use Leopard 3674 brushless motor 2200kv ?
    Oct 2012
    CA
    121
    Red face 6S can use Leopard 3674 brushless motor 2200kv ?
    Dear All master ,
    I have question is my revolt upgarde to Leopard 3674 (2200 Kv) motor and seaking 180A ESC , Prop is M545 or stock prop . Anyone can advise me use 4s or 5s or can I use 6S lipo to play the best speed to run ? I hope can use 6s to play but I afarid too fast and easy to flip .
    Please anyone help me give me some suggestion to me how to setting the trim tab ? Thank you so much !!
    AZ
    8,010
    Don't use 6S with that motor and prop, too fast is not really the problem - it will be too fast - but it will probably burn up first. That motor is best with 4S, it might work with 5S if you are careful. I would start with an m445 prop first with 4S.
    Oct 2012
    CA
    121
    Noted and understand your remind Fluid . I will be use 4s
    to play . But I already buy M545 s/b. Do you think can I use
    M545 prop on this motor ? Please advise !
    Thanks !
    AZ
    8,010
    You can tryt but run for just one minute and check temps. Run another minute and check again. A lot will depend on how you run.
    Oct 2012
    CA
    121
    Noted ! That's means M545 Prop may be make this motor very hot ?
    Is M545 pitch large than X442 ? If yes , it mean will be faster than use X442 prop ?
    Please advise !
    Thanks !
    Oct 2012
    CA
    121
    Sorry ! Typing mistake , it should be M445 is correct not X442 !
