Page 3 of 3 FirstFirst 123
Results 61 to 71 of 71
Thread: Swordfish esc
  1. #61
    Apr 2011
    5,666
    If you purchased it recently, you probably do. The 220+ I purchased from OSE in Nov'13 needed to be updated, but the 220+ I purchased from OSE in Feb'14 was already at the latest release.
    I know you were on the fence about trying the Swordfish ESC. What do you think of it compared to the SK180?
    Yes, I bought it VERY recently! This is my first Swordfish ESC.
    You know, I was prompted by someone ( may be it was you) that the throttle input would be a bit more smooth if it is set at "slow or soft" start, which is exactly what I did, and so I did not feel any perceptible difference today. With all the talk of blowing up even before hitting the water , I was too preoccupied to filter any differences.
    I was seriously thinking of modifying the cooling nipple orientation of the SK 180a ESC so that it will fit in the rigger, but laziness wins once more!
  2. #62
    Jul 2013
    Ny
    131
    What can handle more power a 200 amp esc or a 220 esc?
  3. #63
    Jul 2013
    Ny
    131
    Swordfish esc im talking about. The 220a can handle 6 cell but the 200a can handle 8 cell. Someone please explain how a lower amp esc can handle more voltage. I asked the owner of ose the best answer he gave me was thats how they are designed
  4. #64
    Apr 2013
    777
    watt = amp × volt
    Assuming the wattage remains constant, if the amperage is lower the voltage can be higher.
  5. #65
    Jul 2013
    Ny
    131
    So between the two esc stated above which would be the better of the two on 11.1 volt
  6. #66
    Jul 2013
    Ny
    131
    Sorry 22.2 volt 1600kv 4082 leopard
  7. #67
    6,190
    Quote Originally Posted by wiljm View Post
    I think I used this video from OSE as an example when I did mine.
    Does anyone know of a similar video while using a BEC on a spektrum? Tricky because you have to wait for the BEC to power the RX. Then there are maybe 3 seconds waiting on the radio sinc.................now what? The speedo is in what state at this point?
    Noisy person
  8. #68
    Jun 2012
    1,509
    Same process Terry. I calibrate mine when using the internal BEC and DX4S without issue. I know what you mean about the delay, but it doesn't effect the calibration.
  9. #69
    Apr 2013
    777
    Never had to do that yet, but I will with the Scarab. Never thought about it until now, but perhaps use a cheapo battery holder to make an RX pack just for calibrating.
  10. #70
    May 2009
    AB
    483
    Sir!
    Worked like magic!! I am so near sighted that I guess I had set my screen a bit bigger, I guess that is what Steven meant by resizing, too, I just thought it was a resolution issue.
    Thank you again for all your time! Have a great rest od the day!
    This Forum IS THE BEST!!
    It's an older thread but I was pulling my hair out until I found this solution. Thank You, Thank You, Thank You!
    Namba District 16
  11. #71
    Nov 2010
    OR
    2,493
    If your window looks like the following, I was able to re-create your issue. Go to control panel then choose "display". Set the magnification to "Smaller - 100% (default)", click apply, then either log off and log back on, or reboot. It will make things much smaller, but will allow you to use the program.
    Attachment 117270Attachment 117271
    Reviving this as it saved me thank you!!
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
