Results 1 to 7 of 7
Thread: dinogy batteries
    May 2014
    Ok
    66
    Default dinogy batteries
    I have a revolt 30 that will soon have a seaking 120esc and a 2800kv motor.
    Which on of these batteries would be better to run? Will I be able to tell a difference in the 6000mah to 7700mah?
    http://dinogylipos.com/2s-65c/75-6000mah-2s-65c
    http://dinogylipos.com/10s-12s-saddl...6600mah-4s-65c
    Thanks for any help
    Aug 2010
    uk
    2,887
    A word of warning re the motor kv, don't know what motor you have but 2800kv on 4s is way to high kv for 4s giving over 41,000 rpm unloaded. A 120a esc is not likely to survive long on that set up.
    May 2014
    Ok
    66
    What size window do I have for the 120amp kv wise?
    Aug 2010
    uk
    2,887
    Depends on what motor & size motor you have.
    May 2014
    Ok
    66
    So I will need a lower kV motor. What's the biggest kV I can run with the 120amp?
    Oct 2008
    9,488
    Or a smaller prop like a x437 to start with with that motor on that 120a esc..
    what's the biggest kv to run on a 120a esc you ask? that depends on the prop you are using...
    May 2014
    Ok
    66
    Thanks guys!
