Results 1 to 14 of 14
Thread: 1/16th Scale Hydro - Which motor?
    Sep 2013
    WI
    13
    Default 1/16th Scale Hydro - Which motor?
    1/16th Scale Hydro (wood kit from ClassicHydros) - Which motor would you recommend?
    There are several versions to pick from (below).
    Leopard 2845 Motor:
    winds/rpm:
    2230Kv 4Y (5)
    2550Kv 3.5Y (12)
    2960Kv 3Y (5)
    3300Kv 5D (8)
    3650Kv 4.5D (8)
    4420Kv 2Y (5)
    4700Kv 3.5D (3)
    5460Kv 3D (9)
    Wa
    5,905
    I bought the 3650 for mine though i have not used it. Going to use a single 2s lipo also
    Billy Graham
    Sep 2013
    WI
    13
    Jim,
    Have you tried the 3650 kV in your 1/16 hydro? How did it work out?
    [I am getting ready to build again.]
    Thanks.
    Dave
    Wa
    5,905
    No I have not used it I have shelved the build.
    Billy Graham
    Sep 2013
    WI
    13
    Ok, Thanks. Did you select the 3650 kV based on past experience with something similar, or was it just a guess at what might work?
    Wa
    5,905
    A guess and also other's recommended it on OSE
    Billy Graham
    Jan 2016
    GP
    29
    What esc and prop would you use that motor with?
    Wa
    5,905
    not really sure but I was going to start with an x430 but maybe an x435? I was going to set it up to turn left so there are limited righthand props to try
    Billy Graham
    Sep 2013
    WI
    13
    I'm also planning to have mine turn left, like the full size ones. I might also try a smaller, vintage scale like turn fin - that way I'd be forced to slow down for the turns, just like they did in the '60's.
    Wa
    5,905
    Here is a gallery I did on my first 1/16th build with some video of it running I can dig up the specs for it
    http://www.photosbyjimclark.com/Hobb...lds/Jims-Build
    Billy Graham
    Sep 2013
    WI
    13
    Very nice! Thanks Jim!
    Dave
    Cool
    What speed is the OP looking for? In the larger format 3650 2-pole motors my club members have used the 3500 Kv motor on 2S and the x440 prop for speeds in the mid 40s. Boats are a bit larger, 23" to 25".
    For similar rpm with 4-pole motors I would choose a higher Kv. The 2845/4420 motor should see around 27,000 rpm loaded on the water, with an x430 that should give ~mid-30s which was the speed most of these boats ran with they raced with 7 round cells - I raced them at several APBA FE Nats in the mid-late 90s.
    An x435 might increase speed to close to 40 mph if the motor will turn that much prop, but also increase prop walk and handling woes, especially with a tiny turn fin. Note that a turn fin as mounted in the photo above will cause lifting of the inside sponson, the faster you turn the worse it will be.
    Sep 2013
    WI
    13
    An x435 might increase speed to close to 40 mph if the motor will turn that much prop, but also increase prop walk and handling woes, especially with a tiny turn fin. Note that a turn fin as mounted in the photo above will cause lifting of the inside sponson, the faster you turn the worse it will be. .
    The motor that OSE recommends/sells for their 1/16 Miss K wood hull is the Leopard 2845 Motor (4 pole). They recommend 4420 kV version for 2s, and the 2250 kV for 3s. The details are shown in this link. I plan to run 2s, as the boat is only 22.5" long.
    http://www.offshoreelectrics.com/pro...o-2845&cat=148 There must be a typo as there is no 2250 kV option shown.
    As far as desired speed - I'd like to go real fast, but not spend a huge amount of money doing it. [ I was pretty good at setting up and racing nitro hydros back in the '80s]
    2,731
    I ran a leopard 2860 3400 KV, on 280g 3s 4500mAh, spinning a detounged X432 for a few seasons. The speed in a JAE.12 or 25" wooden cat was about 40mph, with a 5min 20sec runtime or an average of about 45amps.
    With only 3550kv on 2s, I doubt an X430 would get up on the plane if it carries a full size 2s pack unless you can build it out of helium. I would have thought an x637 would be more appropriate to the setup, but they are not available southpaw, maybe something from Propshop or ABC.
