I'm going to me running Himax 3630 1500kv on 4s hydro setup wanting to know what are good battery's for racing the give a lot of punch also minimum 5000mah thanks for looking.
What class are you racing in? I ask because a 1500 Kv motor is a pretty low value for a 4S hydro. If a limited class, then a 35C/5000 pack is enough, less capacity if room or weight is an issue. Don't go under 4000 mAh. A higher C rating may give a bit more speed, and quality cells are faster. Remember that all the power in an FE boat is in the battery.
Charles contact David Newton he has great batteries for running in ERCU
Sent from my SGH-T989 using Tapatalk
Billy Graham
I look into those what about the dinogy 65c 6000mah
I think that is what David sells
Billy Graham
these are the best I have found yet IMO
http://www.motionunlimitedusa.com/in...?route=battery
