Results 1 to 7 of 7
Thread: Mean Machine Build
    71
    Default Mean Machine Build
    I need some advice got a MM nitro hull cheap I converted to FE. used all stock MM hardware and SV motor esc. runs ok but gets hot. I have a hydra 120 and 8xl motor any body have suggestions? also the boat wont turn left 1/2 speed or better tried numerous servos the rudder is exactly across from the prop should I kick it back a couple of inches? Thanks
    1,711
    Have you raised the bottom of the strut up 1/4 to 3/16 above the bottom of the hull?
    Which prop and voltage are you using?
    ReddyWatts fleet photo
    Jan 2008
    Mo
    2,716
    That is a big hull for that motor. I have the same hull but a FE layup and is lighter. You really need to step up to a 10-12 Xl and 16-18 cells. Easy on your gear and will have moroe torque to spin a bigger prop.
    I am trying a 9XL with 14 cells and a 640 prop.
    Strut level with sponson bottom. CG of about 25-30% to keep her light.
    71
    Default MM Build
    Reddy, I have moved my strut even notched it to give me more angle it rides nice the front is up running approx 4" on the rear I am using 2s lipos with a x445/2 blade seems to be the best I think I will set my rudder back 4" get it away from the prop. do you have any advice on the 8xl with hydra 120? thanks
    71
    thanks Jeff anything would be better than the stock SV setup for this hull
    1,711
    8XL on 4s lipo and a hydra 120;
    These props will get the mean machine into the 40's safely. You can try larger props after a setup with one of these. They are all under 100 amps.
    X537/3
    X440
    X637
    71
    thanks reddy I should have it ready to go by next weekend as long as steve gets my order out early(HA HA) let you know how I make out
