Results 1 to 13 of 13
Thread: Setting up dual servo steering-how to?
    May 2011
    NY
    1,483
    Default Setting up dual servo steering-how to?
    I'll be attempting to set up dual servo steering on a large scale (1/5) catamaran hull, using 2 Savox 1270's. I need them to operate in opposite directions for a push/pull type system. What can I use to control the action of the servo's to operate in this fashion. I have a Scott Grey HVX dual voltage regulator to use for voltage control on the HV system it will have and I also have a Gryphon Extreme-Heli voltage regulator as well so either one will work. Just trying to determine if I need a gyro or similar device to operate both servos in opposite direction's. Thanks for any and all input :)
    "If guns cause crime, all of mine are defective"
    45"Speedfreek
    , Fightercat #068 ​, MyYoutube Vids
    May 2011
    NY
    1,483
    Stupid question, but will flipping the servo's in the mount in opposite accomplish this?
    45"Speedfreek
    Mar 2014
    Ma
    1,950
    seems like it would yes. try it
    Mar 2011
    BC
    7,342
    Quote Originally Posted by jj2003 View Post
    That should do it John. I doubt if the extra rod length on one side will affect much
    Mar 2014
    Ma
    1,950
    my question is, why do you want them to go separate directions?
    im visualizing two servos in my head, and even if they turn the same direction, it still should work....
    May 2011
    NY
    1,483
    Quote Originally Posted by Luck as a Constant View Post
    Taking all item's out of the boxes now to try :)
    45"Speedfreek
    May 2011
    NY
    1,483
    They will be mounted on their sides, so I need one to move forward and one to move reverse at the same time.
    45"Speedfreek
    Mar 2014
    Ma
    1,950
    wouldn't having them go opposite directions either both pull or both push at the same time?
    edit: ahh ok.... now i see....
    May 2011
    NY
    1,483
    Testing operation now to see once all the wires are connected. I'll let you know the result's :)
    45"Speedfreek
    Feb 2008
    GB
    2,416
    It would be more normal to set up the push pull with a double ended horn on on servo as normal then run a short pushrod/s from a second servo behind it to assist. that way any minute differences in the speed or distance the servos travel are just a little extra amp draw from the servos fighting each other rather than tightening and loosening the cables allowing the rudder to flutter.
    Paul "tug Killer" Upton-Taylor, Cat lover.
    FastElectricBoats.co.uk
    Dec 2015
    La
    550
    Just curious would you use a y harness or a receiver with two #1 channels.
    Mar 2009
    OH
    1,440
    Why would you need over 900 oz of torque?
    Feb 2008
    GB
    2,416
    You could use an RX with dual #1 channels, or mix one stick input into 2 different channels at 100% to utilise a dual power regulator to supply power to each servo through its own connector. A Y lead would run the current from both servos through a single connector, workable but not the best use of what the OP has.
    "a large scale (1/5) catamaran hull", if that is a modern offshore cat, the model would be in the region of 10 feet long. That would require some torque.
