The new ESC will not help, you puchased pretty much bottom of the barrel lipos, you switced to a more powerful motor in your boat and your revo clmbing a 60' incline with a 10lb rock chained to it will not pull as many amps as a boat! also running higher mah doesnt just give you longer run times it increases the amount of amps you can draw from the pack, a lot of people don't get this? so if you're running 25C 5000's you can theoretically draw 125 continuous amps, now if you parallel 2 sets you now have 10,000 mah and can draw 250 amps, get it? now you can run harder and longer and you wont be stressing the batteries as much, now look at a set of 50C batts and you can now pull 500 amps from the parallel setup!!! get sum new batteries I use the t180's in lots of hi amp setups with good batteries and have never had 1 single problem with any of them.
We call ourselves the "Q"
