I always charge my batteries at 1c but I know a lot of people charge faster than that. Post up what the max charge rate you guys charge at, just curious.
Your battery/manufacturer should dictate what charge rate the battery is capable of taking.
Later,
Mike
2c is just fine IMO.
Again, your battery manufacturer will tell you what is acceptable for the battery. I can tell you that GrimRacer Lipos are only rated at a 1C charge rate. So in that particular case 2C is not "fine".
http://www.aquacraftmodels.com/acces...ipo-packs.html
Later,
Mike
Nobody said I had grim racer batteries... You might, but not everyone has the same brand. I am well aware manufacture suggestions. I would imagine the op has lipos capable of higher than 1c charge rates, hence the reason he is asking.
No I did not tell him that. You should actually read the OP. It asks a broad question. I gave a broad answer. Why all the hostility towards my post? Geez... My advice is valid, answering such a broad question. I'm sorry I didn't sugar coat it for him like an expert would do.
My batteries are capable of being charged up to 5c. That is what the label says at least. I was just asking the question to see what people charge at. I'm sure it's harder on the cells the faster you charge them, I will probably continue to charge at 1c just curious what everyone else does.
Depends on the batteries for me. Most of my 5000 and larger packs get charged at 1C. Smaller receiver packs and 2200-3300 mah airplane packs charge at 2c. I usually don't have a need to go over 2C. The big factor for me isn't the batteries since all my packs can be charged at 3-5C. It's about not pushing the charger to maximum wattage output. Just like on my boats, I try not to push the electrics too hard which keeps things running cool.... and so far has given me five years of trouble free service.
Mike Chirillo
www.capitolrcmodelboats.com
I charge my hi discharge packs at 1.5C MAX. Just keep in mind that regardless the brand and discharge rating, the harder you charge them (as in higher C rate) the more life you take out of them in the long run.
Futaba Team Driver
- IMPBA Hydro Technical Director -
I charge at 2C, but my charger maxes out at 7A so anything above 3500mAh gets just that.
hi guys , this post is what do an it works well for me ,
1- I charge lipos at 1c , even if the label says 5c charge rate, why, because the manufacture would like you to be hard on your batts, shorten the life
so you buy more ,
2- I only fully charge my batts the night before, or the day of running my boat or planes, why, because its hard on lipos to sit around with a full charge in them.
3- when I'm not going to use my batts , for some time , I will charge them up , in storage mode,
these are my ways I treat my batts, an I've had real good long life on my batteries
Thanks for the input. Same as I do.
Why would it be hard on them to leave a charge in them?
uhhh?
no documented proof of shortened life by charging at 5c when a pack says you can charge at 5c
reminds me of a bogus chart someone put up at rcgroups about this
heck even some ThunderPower lipos have a charge rate of 12C !
many users want a fast charging lipo when they go fly or run boats
big debate at rcgroups on just that, fast charging is the way to go some say... and they live by that, and I know of a few who charge at 5C and greater all the time without any loss of power or performance
it's ok to leave packs fully charge for about 2-3 weeks, any longer and they should be stored half charged
something with the chemistry they don't like be left fully charged for a long time, they will loose capacity and power over time
really, I'm glad u feel that way, U must be a battery salesmen ?
12C charge rate listed right here bro
http://www.thunderpowerrc.com/Produc.../TP5000-4SPF70
60A charge rate on a single 5000mah 4s pack
not feelings but specs
I have yet to buy a charger that can actually do this yet
Todd please show us where a battery manufacturer says this^^^.
This from Hyperion.
Lithium Care
To maximize your investment in Lithium Battery packs, do the following:
* ALWAYS Store your packs at 60% of capacity. After a day of flying, use STORE Mode to achieve this. It is especially harmful to store lithium packs fully charged, and should be avoided for more that a day or two at most.
* AVOID discharging cells beyond 90% of capacity (80% is even better). NEVER fully discharge lithium packs.
* STORE your packs in a cool, relatively dry location.
This from Thunder Power
2. If storing longer than one week; batteries must be stored at 3.8V/cell to 3.9V/cell (approximately 50% charged). This is easily accomplished using Thunder Power charger on storage or 50% mode.
like I said, people will believe anything a manufacture will print just to sale goods.
you mite want to check out what the USAF says about lipos they uses for the drones,
Doug this came from LNE who makes Giant Power and Dinogy packs
I have an email from them and not from someones site, saying 2-3 weeks max for a fully charged pack, after that they need to be placed in storage charge
not my words but there's
but....
all my packs are put in storage charge right after race day for best life of the packs
my flight packs are not stored fully charged for more than 48hrs at home...
again no proof manufactures are telling customers to charge their lipos at higher C ratings in hopes their customers will kill their packs in order to sell more???
sounds like that would be a fire waiting to happen in so many homes around the world?
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
uh broad brush..... 2-3 weeks or was that 2-3 weeks
Doug I want to personally invite you to the High Altitude Shootout that my friend and I are putting on
you can run one of my freshly charge erh uh make that my 3 week charged lipo and see how she does
https://www.facebook.com/MileHighMod...17226264982870
This is our club
https://www.facebook.com/MileHighModelers
and our facebook page we over see
https://www.facebook.com/groups/690269474349798/
We belong to Namba20 and really want to take D20 higher and bring the family fun factor for all ages!
Man I'm scared. Scared to charge over 1c. I'd rather wait than be sorry. That's how I roll. It's not worth it to me in my opinion. All my Batts balance perfectly.
I always put my packs in storage mode immediately after use. Just funny about it I guess.
Do some reading on capacity loss fellas.
I'm going to go practice peeing up a rope.
Later...........
I don't mean to bud in here but I always get confuzed on this 1c thing, I use turnigy 5000 2s1p mah and charge tham at 4-5 amps, is takes about an hour.
can someone go over 1c = what ect...
