Results 1 to 3 of 3
Thread: Seaking 180 & 130/180HV
    Apr 2010
    AZ
    643
    Default Seaking 180 & 130/180HV
    I have tried to use the card to program each. I have 3 program cards. 1 new. On the 180 it just shows a minus sign in each window. I also tried thru the transmeter. It just beaps. I have 3ea 180's they all react the same. I plug the batt. pack in the correct slot
    The 130HV the program card just goes blank.
    When trying the transmeter I can get it the program to 6 cells. I need 8 cells.
    Sep 2010
    nj
    4,289
    Are you using the plug in hole on the right of the program card,
    Also is the plug from the esc with the opened ends facing you being plugged into the far right hole on the card ?
    ? ONLY IF THEY WORK
    ON
    9,384
    I know it's old but any 180's around or even 120's????
