In my next project I am going to build an 1/8 electric hydro. I am open for suggestion on the best motor esc combination for this.
Are you intending to race this within a particular organization? Some has specific rules for motor and batteries which limit what you can select.
Tyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
I have been recommended a TP-5840 inrunner 7Y 850KV and a aquacraft 240 esc.
I assume you will not be formally racing this hydro but instead doing some fun running. What voltage do you plan to use? What hull? What are your speed and run time expectations? Your budget? To fully enjoy a model of this size you will need a fairly large pond which is not too windy or rough.
I have every intention of racing .It will be on 100 mts coarse and flat water. The person that recomended that set up racing a lot. He is a Kiwi like me and has raced in the stated
Do the Kiwi's have the same rules as the Aussie's? 1P only?
TG
Tyler Garrard
Hi Barry
I plan to build a 1/8 to compete in Suha (NZ) racing next year. Mostly they run 10s setups here and NEU motors are popular, but I have a more limited budget so a TP power motor will probably be a goer. I have a couple of smaller TPs and they go well. The aquacraft 240A should be ok, or perhaps a swordfish 240A. At the end of the day your budget and prferences are what will determine the choice. Cheaper motors etc have been run in the past with success, but like with any boat the setup, prop, etc will all be important factors in how well it runs. Your current direction however should get you racing/ having fun. You can always upgrade in a year or two.
Check out
www.suha.co.nz
www.nzmpba.co.nz
for rules.
@Tyler, we can run 2P but most run 1P, maybe more of a budget/room/weight thing.
I've got two 1/8th Sport Hydros both have Swordfish 240 Pro Plus ESCs one has a Leopard 5698 910kv and the other has a Leopard 56110 950kv both are on 10s 2p here's a vid of a little blowover lol https://www.youtube.com/watch?v=AQVF...ature=youtu.be
Thanks Peter,
A very popular set-up here is the Neu 1527 1.5Y on 10S. You could also run a Castle 2028 on 8S or 10S. Look for a 1527 size motor from HET or Leopard if on a budget and make sure the ESC you purchase is up to the task.
TG
Tyler Garrard
I'm not suggesting that this is the best setup, but to save money I'm running 8s 1p in mine because I have a lot of 4s packs & it was a smallish 1/8 scale at 42". Also to save money I had a Neu 1527/1Y 1250kv motor so I've put that in it with a Swordfish 240A.
A more ideal kv on 8s would be around 1000- 1100kv to drop the revs a bit & use a larger prop.
Here she is testing a Prather s240 prop. I've ended up using a Prather s235 prop now.
https://www.youtube.com/watch?v=fT9A...Hpw83p9Hn-l1hg
https://forums.offshoreelectrics.com/...hp?albumid=319
https://forums.offshoreelectrics.com/...hp?albumid=320
Has anyone tried the TP-4070 5Y 880kv motor? Or the tp4060 6Y 930 kv?
I have to try this Aquacraft 240 controller!
Grand River Marine Modellers
Where can i find a 1/6 Hydroplane hull?
Never checked.. Fast enough to be an absolute blast!!
In the upper 50s low 60s I'd guess.
https://www.youtube.com/watch?v=zuk-d6chMyg
https://www.youtube.com/watch?v=Y35uoH2t2RM
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
While we are showing off. This was 2006....
https://www.youtube.com/watch?v=NSP3x-SKfT0
I've managed to top 70mph with mine. Surprised the hell out of me.
https://www.youtube.com/channel/UCmc...Hpw83p9Hn-l1hg
...At the videos. That is all.
I have to agree w/ Tyler and Fluid the 1527/1.5y on 10S is the best combo, and the current national champion setup. I've been running this setup in my scales for 6+ years and they are flawless and with the newer batteries we are going faster and faster. Doug Twaits scale at the nats this year was probably the fastest scale boat I've ever seen.
We call ourselves the "Q"
Evening gents, I just bought a 1/8 Exceed gas hydro hull that I plan to put brushless. I see where someone said a Castle 2028 would be an ok motor for this hull. Is that correct? Also should I upgrade the hardware or can I get away using the hardware that comes on the gas hydros? Thanks!!!
