Results 1 to 21 of 21
Thread: 42' Fountain lol.
    Mar 2014
    Mt
    17
    Default 42' Fountain lol.
    First off I am glad to be on here, I am fascinated by scale rc's. I love the look of the Rio's hull, it is just missing the steps. Couldn't beat the cost,@$150 it is my 1st boat if you don't count the Traxxas Villain (before the Ex) I ripped apart when I was young and stupid.(20 stole the electronics) I regret it now. I have been messing with rc since I was 5, first hobby grade when I was 16(Rc10) and worked up to a FtRc10 Gt. I raced a little hated it, bunch of old guys yelling at the kid to get out of the way. Got back into rc when the Scx10 came out, I currently have 6 trucks, scratch built and kits, a 6x6, A scx10, 2cco1's a F650 tow rig Wip, and a jeep wip.
    The Rio, the first mod was to tear off all the stickers, and laid down a silver base coat, going with candy red flames and metallic blue. Next shooting for a 25mph top speed for solid running in the local ponds, lakes and rivers. Probably going brushless when Ican afford it, currently have a couple old 7cell nNiMH battery's and a few mini 2s and 3s lipos including a big 6400 mah 20c battery.
    Everyone loves pic's...
    Mar 2014
    Mt
    17
    Upgrades...
    First will probably be a prop and ESC, looking at the Grapuner grp-2317.40.
    I have a momba monster,not pro and a 550 4pole 4000kv motor,on 2s that should spin up to 29,600 rpms is that to much motor /prop for this boat? Also planing on upgrading the motor mount, is there a recommended epoxy (budget friendly)to glue one in? Also planing on reinforcing the the back 1/3 of the hull, with the same epoxy, possibly replacing the stuffing tube as well.
    Mar 2014
    Mt
    17
    Painted the final color Pactra Candy red,
    I ruined a flame mask, so it will stay 1 color.
    Sep 2010
    nj
    4,289
    Hey very nice,
    That was my first rc boat to.
    And still is one of my favorites to run,
    I modded it to brushless after tweaking the stock brushed setup as much as I could.
    4000kv is to much for that hull,
    Take a look at some of my video's and see if that speed would work for your needs of scale looks.
    ? ONLY IF THEY WORK
    Mar 2014
    Mt
    17
    I really like the way your Rio runs on this setup...
    What is your setup? Prop? Motor? c rating of your battery? Speed control?
    Thankyou for your replies.
    https://www.youtube.com/watch?v=rMT8...e_gdata_player
    Sep 2010
    nj
    4,289
    It;s Running a Seaking/Turnigy 120a esc & HK 3656 2600kv with stock flex shaft and a modded x440/3 prop,
    I run 2s and 3s Turnigy 30c to 40c 5000mah packs or whatever I have on hand.
    Hear some more test post and info for you,
    Let me know if you need any other info on the Rio.
    Because it was my first boat that I learned a lot from,
    With testing and modding setups on in 2010 till now.
    https://forums.offshoreelectrics.com/...=modded+rio+ep
    ? ONLY IF THEY WORK
    Mar 2014
    Mt
    17
    Do you need that much ESC? Could I get away with a 60amp? Only planning on 2s running. The prop I am assuming is a octura 3 blade, 40 mm standard pitch rh spin? Thank you for the links and replies.
    OH
    1,580
    Lower voltage actually takes more amperage.
    Sep 2010
    nj
    4,289
    I still like to run mine on 2s because it just a lot of fun and still pretty fast at 34mph,
    The 60a turnigy/seaking with some add caps should do the job for it.
    And yes the standard pitch & spin octura x440/3 is the prop that run nice and smooth for this hull.
    I like using three bladed props on all my mono's to help stop torque roll on the hull,
    And get a nice ride with pretty good speed to.
    ? ONLY IF THEY WORK
    Mar 2014
    Mt
    17
    Photohoward, I am aware of electrical theory, thanks for the reminder.
    Lenny, sounds like a beautiful setup, it will probably take a couple of months to go brushless, but that is the plan.
    Much faster and the boat looks unrealistic imo. I will be ordering the prop in a week or so, (budget of about $10 a week). Love the look of a big Deep V during through the chop.
    Sep 2010
    nj
    4,289
    You may find some good deal in the swap shop on hear so keep an eye out,
    For the prop and anything else to save a few bucks in the long run.
    I made my trim tabs and turn fins from what I had laying around,
    But they are pretty cheap to just buy and be done with.
    I never did a build thread myself,
    But hears some builds I tried to help with,
    They didn't make it easy to help them sometimes.
    But lots of good info to check out in them,
    And hears a very nice flame job Rio I liked a lot.
    https://forums.offshoreelectrics.com...ushless-System
    https://forums.offshoreelectrics.com...with-stock-esc
    https://forums.offshoreelectrics.com...=modded+rio+ep
    ? ONLY IF THEY WORK
    Mar 2014
    Mt
    17
    Haha, just read those,
    If I didn't want advise I wouldn't ask lol. I like to spend money once on good quality rather than throwing money away.
    I like the setup you posted, so will be using it as money permits.
    What thickness of aluminum do you use for your turn fins/rudder's/trim tabs? Lowes is great for cheap aluminum. Is 1\16" to thin or should I use 1/8"? Also read about using stainless knife blades.
    Emoticons are awesome on here!
    Sun poked out of the clouds today...
    Sep 2010
    nj
    4,289
    Yep, Hated by many loved by few.
    Hears to them all.
    I like a good deal,
    The cheaper the better.
    Looks real nice there when the sun out,
    Could be having some fun snowmobiling or 4x4 running out your back door.
    I used aluminum 1/32" or 0.84mm for the trim tabs and 5/64" or 2.00mm for the turn fins,
    And also made my turn fins 1/2"longer and trim tabs 1/4 longer then the stock ones.
    I picked up three rudders that are 3 3/4" long but had short brackets,
    They where cheap in the swop shop for like $15.00 shipped.
    And than I modded the rudder just a little and added a stand off to the bracket.
    Rudder bracket is mounted from stuffing tube 1 3/4" over to the starboard side of the hull,
    And the back of rudder to the transom is 4".
    I also added a 3/32" aluminum plate to inside of the transom,
    To beef things up there for mounting the hardware.
    ? ONLY IF THEY WORK
    Mar 2014
    Mt
    17
    Wow that is a lot thinner than I expected.
    I have some 1\8" , some 1\16" and 1\32", after I run it the mods will begin.
    Mar 2014
    Mt
    17
    Looking @ the Leopard 3650 in the 2450 kV flavor, with a seaking 60a controller. 36 mm is 540 can dia right?
    Also looking at the water cooled motor mounts, I am thinking about making vertical rails (aluminum) to mount the motor to, that extend to the transom and reinforce everything. Looking at some various epoxys to make everything secure.
    Mar 2014
    Mt
    17
    I dissected the boat today, to get the ESC out.
    Sep 2010
    nj
    4,289
    Hey that looks clean in there, And yes 540 36mm is what you want in there.
    Not sure about the Leopard 3650 2450kv,
    That is a PITA to get to the esc.
    When my stock one blow out I just put the new one right on top of the motor water coil,
    I think it stayed cooler there than in that closed hole.
    The stock motor mount is still being used but the motor clamp screws pull out a couple of times,
    So for the last few years the motor is just held there with hot glue till I do it the right way.
    This is what I was looking at when I just got mine and it was all stock like yours,
    But I picked it up used for $75.00 on CL.
    It was a Long time ago. https://forums.offshoreelectrics.com/...IO-EP-Overhaul
    This was my buddies AKA tunnelvision doing some testing,
    That was till he hit a tree in the snow and took the bow off.
    https://forums.offshoreelectrics.com/...single-battery
    https://forums.offshoreelectrics.com/...io-in-the-Snow!
    ? ONLY IF THEY WORK
    Mar 2014
    Mt
    17
    Yeah I have a problem/sickness...
    I haven't even ran the boat (brand new from lhs) and here I am tearing things up.
    So the electronics box is coming out, and the hardware will be coming off then I will be doing the transom brace/motor rails here pretty quick. It is also getting a full size servo and a brushless system before I ever run it
    Sep 2010
    nj
    4,289
    Yes you should have ran it stock a couple of times.
    Than start doing the modding to it,
    This way you see how far it has come.
    I tweak the $hit out of my stock setup and hardware first,
    Than when I started trying some brushless setup the fine tuning was already there.
    Also just so you know on the servo rod to rudder,
    I used the intake water line hole and moved the servo to the starboard side.
    Than used the old servo rod hole for the water intake line.
    ? ONLY IF THEY WORK
    Mar 2014
    Mt
    17
    As I said sickness... I cannot leave anything alone, from my 1:1 to my rc's.
    They all have to be unique one of a kind... Mine!
    To be fair I should get on and run this thing at least once stock.
    Mar 2014
    Mt
    17
    I put the boat back together today... Dynamite 12t ESC wired in and a big 4000mah lipo in the stock location just have to swap out the battery leads on the ESC...
    Funny thing I have owned this boat 1year 3 months and it hasn't touched the water. I live within 300yards of a creek that should be deep enough most of the year to run, though it does freeze over in the winter. It will run this Summer!
