Hi guys, I wanted to show you the micros we built. A friend and I built two of these. We used the free Doug Forrester Hydro Mite plans that I scaled down to produce a 14 inch long boat instead of 16. I also changed the front sponsons a bit. We had planned to run them in a back yard pond but they are way to fast, even on 2 cell lipos. The boats are very fun to run and the speed surprises everyone who sees them. I got mine to run even better then what you see in the video. That was a winter test run, the first run on 11.1v. My friends boat was a crasher. It had a twist in the hull and flipped every time it became airborne, which never took long. If your looking for a fun to build and run boat, I highly recommend one. We used Mystery brand 3000kv motors and 25 amp speed controls. They are very affordable. .098 flex cables in a brass tube with no liner, hand made hardware and cheap 1300MaH 11.1v LiPos. My best prop was a cut down to 31mm Octura X432. It was very sharp and thin. I also removed the tongues and balanced it. Worked well. Thanks for looking. Here's the vid... https://www.youtube.com/watch?v=p2W-MTwmMaI
Here's mine sitting next to my Micro Scat cat.
