First, two 2S packs in series to make 4S does not double the amps the pack can deliver. Most agree that you cannot trust the 'C' ratings on most LiPos. My recommendation is to get nothing lower than 35C, even for relatively low-draw applications like the MG 29. Too, the ESC does not draw anything, the motor does. It is not uncommon for racers to draw well over 75 amps with that motor spinning a large prop. Usually the ESC is under-rated a bit and handles it.
All the power in an FE boat is in the packs, the motor just converts electrical energy into rotational energy. Spend a little bit more on higher quality packs, you will thank us.
Cheap packs, don't be this guy......
