i have a 33 inch titan mono that im trying to setup. is it better to use a stinger drive or regular strut setup for 3/16 drive cable ??. what is the proper setup when using brass tubing or teflon tube thru the hull ? if you are wondering, im using a 4082 leopard motor on 5s 4500mah 45-90c lipo batteries. most waters i run in are a little choppy to rough. i need any suggestions on what site to go to purchase the hardware. is there actually a site for speedmaster hardware for electric setups other than offshore electrics. parts i need are not in stock at OE
